S88 Compared to a Large Frame GT47 88MM turbo
Old 09-04-2007, 03:47 PM
1INSANEGTO's Avatar
Default S88 Compared to a Large Frame GT47 88MM turbo
Pics. Which one is smaller.
I am told the S88 & S91 is as big as a GT42.
Old 09-04-2007, 03:54 PM
LS1TECH Sponsor
DrTurbo's Avatar
The S88 and S91 are the same frame size as the GT42. The GT47 is much larger indeed, and also much heavier. S88-S91 is 47lbs vs GT47 is 59lbs.
Old 09-04-2007, 04:06 PM
1INSANEGTO's Avatar
cool.
Old 09-04-2007, 04:37 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Is there a S turbo that is like 94-98mm?
The ship weight of my GT47-88 was 60-65 lbs, with the housing.
Old 09-04-2007, 04:40 PM
LS1TECH Sponsor
DrTurbo's Avatar
We are working on some different models right now. Should be able to do from 86mm to 100mm in a mid thumper style, then all the way up to 122mm later, once some product support is released.
Old 09-04-2007, 04:49 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
S95..... 98lbs of glorious turbo
Old 09-04-2007, 04:50 PM
7 Second Club
Phil99vette's Avatar
Whats going to be the max hp supported by a 122mm compared to a t-netics 106?
Old 09-04-2007, 06:37 PM
SSilverSSurfer's Avatar
on their website it says that the s122 is at the 2xxx(hope that first "x" is a bigger than 0). im guessing it'll be significantly lighter than the t-netics one.
Old 09-04-2007, 07:10 PM
7 Second Club
What does a T-netics 106 support 2500?
Old 09-04-2007, 07:13 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
They claim 2200
Old 09-04-2007, 09:22 PM
99Z28LS1's Avatar
these are all MASSIVE turbos...... 1 day..... 1 day
Old 09-04-2007, 09:49 PM
SuperZ's Avatar
so when I go with a 408 I could directly swap out my GT-42 76mm T6 for a S88 or S91??That would be so awesome!
Old 09-04-2007, 11:41 PM
the PT106 is 2400 and the T-106 is 2000
Old 09-05-2007, 07:08 AM
1INSANEGTO's Avatar
I am looking to run the S91 on my 408. I have to get my heavy *** GTO into the low 9's
Old 09-05-2007, 09:30 AM
LS1TECH Sponsor
DrTurbo's Avatar
Yes its pretty much a direct swap. We do use a slip outlet on the compressor discharge though compared to the V-band discharge for the 85mm and larger units.
Old 09-05-2007, 10:04 AM
1INSANEGTO's Avatar
Dr.Turbo call me I need to order my S91!!!!!!!!!!!!!! I have called a few times stop playng on the interweb lol
832-351-7173
-Tim
Old 09-05-2007, 11:09 AM
LS1TECH Sponsor
DrTurbo's Avatar
832-351-7173
-Tim
Old 09-05-2007, 12:43 PM
otherwhitemeat's Avatar
that is not correct....a t101 will make 2000hp and a t106 quit a bit more
Old 09-05-2007, 12:44 PM
obZidian's Avatar
Man, you guys are absolutely............... awesome!!!!!!!
And, before i got my s85, I thought that the s88 was the big boy s-series. Well, the s88 is a kid brother compared to what ya'll have in the works.
I really, really see myself going for a s95 in the near future....
Old 09-05-2007, 05:38 PM
NA$TY-TA's Avatar
The S95 in no way compares to the S88 or S85.....
It is a Thumper and is HUGE..... needs quite a bit more room then the S88....
Kyle
Quick Reply: S88 Compared to a Large Frame GT47 88MM turbo
