Anyone port the head chambers to drop compression.
Its a 370 with 12cc Mahles and 72cc 317's. With a GM MLS gasket, compression looks to be around 9.5 to 1. I was thinking of polishing or opening up the chambers a little to drop a couple points. Or should I just use a thicker gasket. recomendations???
OK to do if you know where there is extra material to be safely removed. Risky if you don't, unless you are just polishing everywhere and only removing a total of ~2cc's of material.
I wouldn't go over a .041" gasket. Is your deck zeroed to your pistons or are you slightly 'in the hole' at TDC? If your deck is zeroed, you could get a .050" gasket in there.
What's the worry? Just intercool the hell out of it, and then add alky if you have problems.
Jim
Jim
Originally Posted by blown90lx
nothing wrong with boost on 9.5:1. you will just have to run race gas on high psi. as long as you have a good intercooler to keep the iats down. my 382 is at 9.8:1
and how much boost can u run on pump fuel say 93 for eaxmple--
Dumb Ass Vette Moderator
Keith
