so i was bored today and fabbed up a different alternator bracket
decided to mess with my TA and wanted to find a easier way to make a bracket.
the alternator sits a little lower in case anyone needs to use this for an rx7 swap or any swap were they are worried about hood clearance.
also its easier to clear aftermarket fuel rails, and hopefully still is out of the way for taller valve covers.
tried to get the belt out of the way down below to if anyone needs to run a downpipe back on the driver side
hopefully it looks clearer too as the only visible piece besides the alternator is a polished aluminum piece.
a friend of mine is suppose to try it out next week and see how well it works, as my car isnt moving as of late (got to get the tranny going)
still need to get the right size belt and bolt lengths.
since its easier to make its le$$
Originally Posted by daniel6718
so one bolt goes directly into the waterpump and another uses the bracket you made?
the actual alternator bracket is a simple piece, but the tensioner bracket is a bit more complex.
Hydraulic lines are easy....Mine swap from left to right anyway, being right hand drive...
But if my PAS pump wasnt there, it would leave room for a V4-XX or even a Z trim instead of my YSi, in my existing bracketry.
Just a notion Im thinking about, probably wont happen though....
