How bad is the 6-rib
Old 10-09-2007, 10:04 PM
Hawk108's Avatar
Default How bad is the 6-rib
I searched and found a little bit of information on this, but wanted a little bit more. Exactly how bad is the 6-rib setup on a car running about 6-7 lbs. of boost? I know its really bad when you get into bigger boost numbers, but is it horrible at low boost also? Another question is about how much does it cost to switch to the 8-rib system? Thanks in advance.
-Noah
Old 10-09-2007, 10:49 PM
DeltaT's Avatar
If you don't slip on a lo-boost 6-8# setup with a 6-rib, an 8-rib won't do a thing for you.
Switch to 8-rib is: 1 wider belt, 1 blower pulley, 1 idler pulley, 1 crank pulley, plus anything else on that belt. Figure $400 in a pulley/belt swap, maybe $500.
Jim
Old 10-09-2007, 11:52 PM
my01ws6's Avatar
I too am trying to figure this out...Im going to be running a stock motor with about 8lbs of intercooled boost...Is the 8-rib setup absolutely necessary? My goal is 500rwhp DD.
To answer the thread starter...I believe you also have to pin the crank when using an the crank pulley for a 8rib set up. I may be wrong tho.
Old 10-10-2007, 02:26 AM
mahhddgtp's Avatar
newb question. What does pinning the crank do?
Old 10-10-2007, 05:12 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=716
This kit includes all the other parts that are required for the conversion, plus links to the harmonic balancer and the crank pinning kit that are required. Bob
Old 10-10-2007, 09:15 AM
Dumb Ass Vette Moderator
ls1290's Avatar
A 6-rib setup should hold 6-7 pounds of boost with no problems.
Keith
Old 10-10-2007, 09:21 AM
ls1290's Avatar
Pinning the crank puts a metal pin between the crankshaft and the harmonic balancer to help prevent the balancer from turning/slipping on the crankshaft. The supcharger puts extra load and tension on the balancer. This extra load can sometimes cause the balancer to slip when it gets too great. If the balancer slips too much it can loosen the balancer bolt and cause the balancer to come off.
Keith
Old 10-10-2007, 09:41 AM
gauge hp's Avatar
I have been running a 6 rib and 7# now for about 12k, zero slippage, and same belt!
Old 10-10-2007, 12:27 PM
Hawk108's Avatar
Bob I sent you a PM.
Old 10-10-2007, 12:33 PM
WHPLASH's Avatar
I'm at #12 with a larger crank pulley.
Old 10-10-2007, 03:17 PM
Blackbird's Avatar
same with my buddy.
we made a home made system and with the larger crank pulley he makes 12# and 650rwhp all day on the 6 rib.
Old 10-10-2007, 06:10 PM
Rickys S/C Z28's Avatar
good to know!!
Old 10-11-2007, 12:07 AM
my01ws6's Avatar
So would you guys say a 6 rib setup is good for us DD guys that see VERY LITTLE track use?
Old 10-11-2007, 09:02 AM
WHPLASH's Avatar
The 6 rib setup is fine. But once you start getting up there in boost, you'll need to upgrade. You won't stay at 6-8lbs for long. Trust me.
Old 10-11-2007, 12:53 PM
TX RED's Avatar
I Have Both Pulleys For Sale 60 For Each 6 And 8 (4.25)
Quick Reply: How bad is the 6-rib
