What tensioner are all the FI guys running?
I ran the turbo SS yesterday and threw the belt on what would have been my 10-second pass. 1.66 60' 7.1 1/8 @ 100 and then pop goes the belt. On the next pass the belt jumped halfway off the tensioner and got cut so I called it a day.
What tensioner is everybody using? manual tensioner, replace with new stock one, etc?
thanks
thanks
I actually have a process.
I put the my normal belt on a manual tensioner and move the tensioner to it's max to stretch the belt. Sometimes I'll drive around like this to stretch the belt a little better.
I then remove that tensioner and put the stock spring tensioner on and ensure that the stock tensioner is just a smidge off of the fully extended limit.
I haven't had a belt get thrown since going this way. If I put an un-stretched belt on the stock tensioner I throw the belt. If I run the manual tensioner I will eventually throw the belt.....it just takes a few weeks.
there was a write up using a 3.8 supercharger tensioner- as it has a high side that keeps the belt from jumping off, and it is cheap when compared to other companies tensioners.
LS1Tech Co-Founder
The ASP one is pretty cheap too, but most of us defintely should run a high lip pulley for the idler because of the rpms we run and what the belt does when you let off... the belt is like a sine wave and it whips off.
Katech here....its quite nice.
Although my blower drive is dedicated, and also has a manual tensioner.
I think I was only throwing accessory belts, as the stock tensioner was knackered though.
TECH Cry Baby BOSS APPROVED!
This thread has the info for you to convert to the 2000 Regal supercharged tensioner pulley.
https://ls1tech.com/forums/generation-iii-external-engine/749847-buick-tensioner-pulley-swap-pics.html
8 sec potential, 12 sec slip
https://ls1tech.com/forums/showthread.php?t=749847
