427 + D1 = Hot headers
Old 10-17-2007, 09:29 PM
LC
LC's Avatar
Default 427 + D1 = Hot headers
We built a 427 LSX 2008 RC silverado (cheyenne down here)..
D1 pushing 12 pounds...
The thing is that after a hard wot, not even a full track pass, just a hard wot on the street, we open the hood and the headers are flaming red...
Is this "normal" or should we look into other brand/type/or material for the headers?
Thanks for any input..
edit: headers are edelbrock
Old 10-17-2007, 09:31 PM
SSilverSSurfer's Avatar
what kind of headers do you have now? coated or not?
Old 10-17-2007, 09:33 PM
LC
LC's Avatar
just edited the post... headers are edelbrock not coated.. (grey color)
Old 10-17-2007, 10:34 PM
98turbls1's Avatar
Are those stainless??? If not then I would try to wrap them to see if that helps... I personally would go with some QTP or something equivalent... How hard are you pushing that blower?? I'm thinking of going with a LSX block 427 but was wondering if I'd even be able to strap the D1 onto it...
Old 10-17-2007, 10:41 PM
edcmat-l1's Avatar
Several things cause headers to glow. Way too rich, way too lean, timing too retarded, shitty headers. Take your pick.
Headers should be coated at least. If they're not, get em coated inside and out. That alone may take care of it.
Old 10-17-2007, 10:44 PM
DeltaT's Avatar
Doublecheck the timing. If it's seriously retarded, the headers will glow due to the final combustion taking place in the headers instead of the chamber where it belongs. Worst case it will burn through your headers. Remember that the timing can be retarded via the knock sensor and knock retard, so check that too.
Jim
Old 10-18-2007, 12:28 AM
Closed Sponsor Account
Josh@MASPORT's Avatar
how about a very restrictive exhaust, but i would put my money on thin walled uncoated headers being the problem
Old 10-18-2007, 02:36 AM
njc.corp's Avatar
Lets see some pics to see how thin or thick the material is-
lets see something-
Old 10-18-2007, 07:48 AM
texada's Avatar
you need to get that car professionally tuned before you end up buying another shortblock
Old 10-18-2007, 07:59 AM
YellowToy/A's Avatar
If you dont have a wide band get one.
Old 10-18-2007, 12:27 PM
2000 Tran Zam's Avatar
Jim
Haha, that just doesnt sound very politically correct
Old 10-18-2007, 02:28 PM
LC
LC's Avatar
The guy that tunes our cars has HPT and a LM1.. i have not talked to him yet.
Im going to check the exact model of the headers, do some research on them and have a chat with the tuner..
Old 10-18-2007, 05:35 PM
ExceSSive's Avatar
Is it lean because I have heard that a lean condition can make your headers get really hot.
Old 10-18-2007, 07:30 PM
Websy21's Avatar
Definitley get that thing tuned, that doesn't sound good at all. Even if they are shitty headers
Old 10-18-2007, 10:23 PM
DeltaT's Avatar
Sorry, should have said "Glowing like a ******* Mongoloid"!
Jim
Old 10-19-2007, 12:30 AM
LC
LC's Avatar
Headers were 1 3/4... never noticed that when installing (such a rush to finish it)..
We are switching to custom 2".. they started today.. lets see what hapens.. just saw some AF logs and truck is not lean.. if any, it is still a bit rich.. timing is low, but not that low..
Old 11-03-2007, 01:23 AM
abbaskhan's Avatar
im wagering they are too thin.... try coating inside and out
on a set we had to coat inside and out as well as wrap to keep heat down
Old 11-03-2007, 03:34 AM
LC
LC's Avatar
We got a custom 2" haders made and that solved the problem, truck is running fine, we will be trying a F1 by the end of the year
Old 11-03-2007, 08:49 AM
Fb0dy0nly's Avatar
thats what I was going to say, 427 plus blower = bigger headers.
Quick Reply: 427 + D1 = Hot headers
