4" DP Question
Old 10-25-2007, 07:13 PM
Twin76mmTA's Avatar
Default 4" DP Question
I know the formula to figure out the CFm that can be flowed through a 4" pipe but since i don't know the velocity of the exhaust exiting the turbo i can't figure it out.
So as a rule of thumb how much HP can a 4" DP support?
Old 10-26-2007, 07:06 AM
smokinHawk's Avatar
allot
probably around 1400-1500rwhp, maybe more but backpressure will increase
Old 10-26-2007, 07:39 AM
EspaceF1Fan's Avatar
Will you have one or two 4-inch downpipes?
Whats your power goal?
Also, keep in mind alot of 4 banger guys find 4 inch downpipes to add some power even at a lowly 450-500hp(thats the point they see 3inch as a restriction), so maybe a 5 inch is in your future? I'm sure a 4 inch has to support up 700-800-ish atleast.
Old 10-26-2007, 08:40 AM
RealQuick's Avatar
3" has supported 1000rwhp depending on cubic inch.
Old 10-26-2007, 09:14 AM
jason99frc's Avatar
In a regular exhaust application a single 4" exhaust is good for 675 FWHP before a restriction in noticed. I would expect the same or a little higher for a Downpipe on a turbo setup so 1300 - 1400 ish should be on target.
Old 10-26-2007, 09:35 AM
LS1Tech Sponsor
Slowhawk's Avatar
It also matter's how long the pipe is too.I've seen people run low 7's with a single 4" pipe but they ussually go 5-6" around then.
Old 10-26-2007, 10:31 AM
On a SINGLE 3 inch pipe? If so they were really hurting themselves...
Old 10-26-2007, 10:37 AM
RealQuick's Avatar
Not saying its optimal, but it has been done. The mustang guys 306ci-347ci have pushed the single 3" pipe.
Old 10-26-2007, 11:58 AM
Gotcha...
Quick Reply: 4" DP Question
