Magnacharger dyno results
Finally got the proper pulley on the maggie. I'm now consistently seeing 6-7lbs of boost. I'm still having belt issues. Even shredded one on the dyno. While there, I could see the tensioner not only move up and down, but side to side. One of the tuners actually pointed it out to me after we replaced a belt and said that's the problem. Maybe I just got a bad tensioner?? Anyway, here's the graph. BTW, I think it's time to replace my valve springs. They have a lot of miles on them and I bet the graph would smooth out some with new ones.
The kit contains the spacers and longer bolts needed to lower the k member. It really doesn't change the angle enough to worry about. People put small lifts on trucks all the time without issues. That changes the angle a lot more than this. Even worn out motor mounts can change the angle, but that doesn't have any ill affect on other driveline components.
Sweet I have a Vinci XXX (222/228) cam and Crane rockers......this deff seals me lookin into the Dart heads with the charger. Your graph is bassically what my target was....its also good to hear it has the nice driving manners.
Awesome numbers Tim! looks like your tuners did a real nice job
On the belt issue, if you need another tensioner, let me know I have one here I can send. Did you get the crank pulley spaced back out properly from the modified lower timing chain gear? If that's still off a little, it could be moving the belt front to back and causing some trouble?
Anyway, congrats on the power, looks good, let me know if you need anything,
Ed
Ed
