Reverse rotation Procharger?
Old 11-01-2007, 10:30 PM
stoverz28's Avatar
Default Reverse rotation Procharger?
My father has a p1 nib from an unused set-up, and i would like to buy the head unit off of him. Now i have heard something about f-bodies kits needing a reverse rotation procharger because they are mounted on the bottom right instead of at the top. Is this true? or are the all the same just rotated to a new position for the f-body?
Old 11-01-2007, 10:58 PM
gametech's Avatar
I don't know if you need it or not, but the R designation in some of Procharger's models means reverse rotation, so they are NOT all the same.
Old 11-01-2007, 11:39 PM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1227
This clocking rotation guide will help you out. Bob
Old 11-05-2007, 08:21 PM
goodol'93z's Avatar
Default ?
can a standard head unit be reclocked i see something about reworking the oiling system on epp's site.
Old 11-06-2007, 04:56 AM
EPP
EPP's Avatar
Smile
You can reclock the ProCharger to rotate the unit around to where the outlet is where you need it to be. Doing this does not change where the oil pump mechanism is located in the unit. Bob
Old 11-06-2007, 07:09 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
The location has nothing do do with rotation. Rotation will be effected by which way it faces. And yes, the f-body units are reverse rotating units with the inlet facing forward.
Old 11-13-2007, 08:09 PM
97rs4life's Avatar
so looking on ebay or something how can you tell if it is reverse rotation? Or are all capable of it? Wondering what I need to look for when buying a headunit
Old 11-13-2007, 08:19 PM
Rickys S/C Z28's Avatar
do your self a faver and call bob @EPP that way you get what you need the first time around
Old 11-13-2007, 08:20 PM
EPP
EPP's Avatar
Exclamation
The best way is to know what it came off of, or just buy a new one, as you're taking your chances on a precision part from Ebay. There's a lot of scammers on there. Bob
Old 11-13-2007, 09:25 PM
97rs4life's Avatar
well the issue I have is that I have a 3.8l fbody, not the ls1 or lt1. So a kit would not work for me, at least the mounting bracket and such. There is a person that custom made a bracket for her car and it is running some nice numbers. So I am just looking for options or to make my own kit because the only procharger kit available for our 3.8l cars is like 4500 dollars from MACH performance in MI.
I feel it can be made for less if you ask me or offered for less at least with a used or rebuilt unit and not a new one. And they are not using the d1sc headunit either on that kit
Old 11-13-2007, 10:57 PM
ChevyChad's Avatar
Even if you get a used kit in decent condition, you will spend at least 3000. But seriously, WHY put that on a V6?
Old 11-13-2007, 11:07 PM
97rs4life's Avatar
because I can...and run 12s, 11s, just like you v8 guys can.
Already have two stages of nitrous on my car, looking for other options. My brothers car 99 firebird 3.8l we have put a powerdyne unit on that we built ourselves and is running good as well.
leave the v6 bashing alone, I am just hear to learn about other options.
Old 11-14-2007, 05:19 AM
forcd ind's Avatar
you can get the serial # off the unit, and call procharger, they can tell you what rotation it is-(i have a vette setup, i'll look at the serial # and see if it says anything about rotation) if your mocking up a self contained unit(sc) the drain plug has to be pointing to 6 o'clock for the oil slinger to work correctly
Old 11-14-2007, 05:31 AM
EPP
EPP's Avatar
This guide should help you out. Give me a call at 260 244-4808 for a price on a new head unit. If you buy a new head unit and just the main bracket assembly, then piece the rest of the kit together with used parts, you have the potential to save some money for your V6. Bob
Quick Reply: Reverse rotation Procharger?
