Help me make up my mind...
I recently ran out of patience with an STS kit. I think the Turbo needs to be rebuilt (anyone want an intercooled STS kit cheap?)
I'm trying to decide what to get next. Supercharger (F1A) or Turbo.
I'm in no way an expert in FI, but with some very good advice from a local board I am torn.
I've been frustrated by turbo companies not answering questions specific to my set-up or getting the run around, but they all want my money.
So what do you think would compliment my set-up?
Engine:
Advanced Racing Dynamics 408ci Iron Block
Callies Dragonslayer Crank
Compstar Rods
Dished Diamond Coated Pistons 9:1
Heads:
AFR 225's
4.0 bore
68cc chambers
2.08/1.60 valves Hollow stem valve upgrade.
8019 valve spring upgrade.
Intake:
Victor Junior
90mm Nick Williams TB.
Engine:
Compstar Rods
Heads:
AFR 225's
4.0 bore
68cc chambers
Intake:
Victor Junior
I'd like to make 800+, but I don't care about dyno numbers so much as 1/4 times.
That's the going opinion right now.
is keeping ac important??
the F1 will give you more than enough power...but ya need to worry about the belts slipping/pully alignment issues that come with superchargers.
most turbo kits out there require you to move stuff around and lose something ie. A/C...ABS...etc.etc. if none of this matters to you than your in good shape. if it does, look into the APS kit...i have it and your more than welcome to come check it out when your in town (Philly).
turbo kits...ya wanna check with companies like APS...Stenod...Speedinc...they have great customer service and will go out of their way to answer any questions you have.
Superchargers...theres really only 1....EPP...talk to Bob.
ABS is off because I needed better wheel studs and I hated the ABS block in the engine bay. So not a problem.
I won't be in Philly till... April at least. But I'm sure I can take a run up to Sunoco one night, or OCB in York.
I contacted "Pete" at APS and they only offer one turbo set-up for engines up to 400 CI. Couldn't really give me any tech support for my set-up.... so
I am currently talking to TTi.
I wrote to EPP this morning. Waiting to hear back. Seems like the cheaper option too. But have always been weary of SC'r belts etc.
My gf's Novi 2000 runs nice on her stang, so my mind's been changed a lil.
This is why I made a thread. I seriously don't know what to do.
to really run what that motor wants, you would need to do some hacking to fit a large frame turbo on the car on a custom system
any t4 single or small twins will be giving you a **** ton of tq and get into a pressure ratio efficiency situation at high rpms.
can a single t4 or probably even small twins put the car into the 9's? i would definitely think so.
i have a t4 flanged PT88 on my car, that turbo is good for at LEAST mid to low 9's.
i love my turbo set up, never owned a blower though. Turbos just seem like more fun...
It all depends. They both have their advantages and disadvantages. My vote is go with a F1A blower from Bob at Exotic Performance Plus. The supercharger route is much easier to install and basically trouble free. Yes turbos are more efficient than superchargers but look at what I have run with my F1A blower with a 6-speed at 3800 lbs. I could but an auto in it and run low 9s but I love having a stick so running alittle slower is fine with me.
but one on a 400 inch motor.. the turbo is in a much different place on the map than my 364 or yout 370
every 12 revolutions you are stuffing another one of our engine's worth of air through that turbo... and at 6500rpm that happens 9 times a second.
With that engine setup I would go with the T6 turbo kit. I offer one that will keep all acc. The s-series turbos work great with the setup also. At the end it comes up to how much money you want to spend and whay HP you would like to get to. Give me a pm if you have any questions.
Thanks Joel
Thanks Joel
Take a look at my car here. http://www.exoticperformanceplus.com...Car.php?car=12 The engine combination is pretty straight forward.
All in all we have more problems with turbo related oiling problems than we do with blower belts on superchargers. Bob
either of them will make the power your are after, easily.....turbos may make alittle more power but I love the whine of a blower and wouldn't have any problems running one...
yes i know a t4 turbo can go low 9's
see that what i get for reading it as a general statement, not application specific. i just cant imagine you know anything about turbos, not like you have ever owned or raced one
