Anybody know if the new turbo BMR k member will work with the Fbody APS TT kit?
Has any body used the new BMR turbo k member with the APS TT kit?
I was doing some research on the new turbo k member and seems to give you way more room then the standard k member for the f body. Apparently it gives you the room for 5" down pipes and larger turbos. Any info would be great before i order mine. Thanks
I have one in my garage sitting beside my APS kit
I have not installed it yet
I do not think it is going to give any more room on the APS
kit
but I think that maybe later on I may build a custom twin kit around it and went ahead and forked over the extra 100 bucks for it
kit
i was just checking out pics on aps's web site and it looks like the turbos sit further back then the k member anyway so like you said it might be useless for the APS kit but let me know if it might be good cause i'll fork over an extra 100 bucks for it also
The BMR shouldn't need for you to modify things as it was the one the kit was built around correct. I know you need to modify some of the frame to provide good clearance. Does the UMI k-member require modifications to the APS kit itself or the k-member.
Oh and JMBLOWNWS6 awsome build on your car, very nicely done.
