Give me your PUMP gas numbers!!
Question for all of ya'll! That's fantastic that you can pull 800rwhp with a nice mix, but have any of you guys dyno'd with just pump gas? I'm trying to figure out what is realistic and what's not. Please state if you are using Methanol injection. (93 Octane U.S.)
its dumb to go past 800 on even a big cube LSX motor.
if its a track car, use race gas
if its a street car, you ain't hookin over 800whp
and if you do turn it up for a night in the street, put in some good gas :bang2:
can it be done? yes
is it risky? hells ya
can it be done? yes
a big sack and money to replace an engine
dont get me wrong, alot people do it. i've been there. its just A LOT of power to think you are going to do it reliably and have your engine last on pump gas.
what's the most power you've had out of curiosity? i see a lot of guys doing the 500-->800/1000hp jump that want to do it the cheapest way possible
Lol, Well, workin on both those. So my desire for 750 RWHP on pump ALONE is not completely unreasonable? I wat to be able to drive my car to work when ever I feel, (without spending $10 gallon for 116) But I plan on putting in a few gallons of 116 on the weekend just to turn up the boost and have some fun. Any input guys? anyone doing this sorta thing?
made 890 rwhp on 12 psi and 93, no meth.
I made 1 run at 16 psi and emade 990 rwhp also on 93 no meth. But the most I run on 93 is 12 psi. Not worth risking more then that, and can't hook even 890 anyway
i had a 76gts 365ci setup. it made 749whp on a conservative tune. with some changes and boost, i guestimated it was making close to 800w this year.
next setup is a 408 w/ a S88. more cubes and turbo you got, more power you can make on pump
yup. main reason i took it apart was the clutch pushed my crank forward. but i also had a little bit of detonation. not much, but enough. good too greedy on pump.
the new setup i will probably only take up to 12-13 psi on pump with LOW timing
