world ls1x heads good for FI?
Old 11-25-2007, 03:01 PM
ls1408cp's Avatar
Default world ls1x heads good for FI?
Are these heads any good? Does any one use them? They have thick decks and dont cost a ton? I am thinking about buying a set.
http://www.theengineshop.com/prods_pages/025050.htm
Old 11-25-2007, 03:02 PM
ls1408cp's Avatar
I hope the stock rockers fit.
Old 11-25-2007, 03:43 PM
DanZ28's Avatar
I guess they would be fine. Do they only have an as cast version? You also might check into a better spring and a little more seat pressure. How much power and boost will you be expecting?
Old 11-25-2007, 04:09 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That's the best price I've seen them for. For that cheap you could buy them and send them out to someone to port. You'd have huge numbers and come in slightly above or even with buying an off the shelf part. NA$TY-TA said he was going to do exactly that on his new setup.
Old 11-25-2007, 04:30 PM
ls1408cp's Avatar
I am hoping to make 1100rwhp with a s91. That is a cast version. The base spring did look a little weak. I am just looking for a thick deck. I should be in the 22-24psi max range on a 370 or 408.
Old 11-25-2007, 04:37 PM
NA$TY-TA's Avatar
Im running them but with a 1.550" spring and doing a solid roller setup so the spring pressure on them are way better.
We are going to do some hand blending and porting them to my intake. I haven't flowed them yet, but I do plan to. There still sitting in the box since I was waiting on JE for my pistons forever..........
I won't be using stock rockers so k can't help ya there. Sorry
Kyle
Old 11-25-2007, 04:52 PM
platinum1's Avatar
pm sent
Old 11-25-2007, 06:36 PM
BoostnTBSS's Avatar
I have them and i will have the flow sheets soon on them seeing we did some minor porting on them. i should have a engine dyno done by xmas too.. with s-70,s-74, and s-88 will also run a Y2K 88 and prob about 4 more custom turbos to see what works the best with my combo. i will post soon
Old 11-25-2007, 09:33 PM
Josh@KY-Turbo's Avatar
Huh... I like the price of those to. Might try them on the LS2 36Xci engine. I was gonna do a L92 setup.
Old 11-26-2007, 09:08 AM
ls1408cp's Avatar
I thought l92s had a weak deck?
Old 11-26-2007, 09:28 AM
LS1Tech Sponsor
hellbents10's Avatar
They do.
Old 11-26-2007, 11:02 AM
Firechikn's Avatar
Like said, I would through a set of bigger springs on there and let it rip. Should be pretty good out the box. I'd like to know what they flow too.
Old 11-26-2007, 12:10 PM
They are cheap. I am building a street car this time around. Heat, Over Drive, Street tires, Stereo, Ect... I may go back with a set of the 317 6.0L heads. I am not looking to set records or run 8's this time around.
Old 11-26-2007, 01:33 PM
deadmanTA's Avatar
Wow, I never checked the prices on those. Figured they where going to be more than the AFR's.
Quick Reply: world ls1x heads good for FI?
