Need turbo inlet assembly for old qmp kit?
Old 12-10-2007, 12:08 PM
SPRAYED 01's Avatar
Default Need turbo inlet assembly for old qmp kit?
I put an old qmp kit on my car. the only thing that was missing was the inlet pipling with filter assembly. Im having a hard time finding 4inch tubing with a 90 bend. Any ideas or if anyone has what came with the kit or pics of what came with the kit.
Alex
Old 12-10-2007, 05:13 PM
SPRAYED 01's Avatar
tttttt
Old 12-11-2007, 09:17 AM
MASS seller approved
Time2Kill's Avatar
Contact Stainless Works. They continued to make the kit after QMP went under.
Old 12-11-2007, 11:29 AM
SPRAYED 01's Avatar
Stainless works is doing some research for me. Does anyone remember if if was a 4"to 3" reduced tube?
Old 12-11-2007, 09:12 PM
SINISTER's Avatar
im pretty sue it was 4-3 inch tube...
do a search im sure you can find some old threads..or see if rob is still a member andpm him and ask him
Old 12-12-2007, 02:18 AM
black98ws6ta's Avatar
It did not go down to 3 inches. There was a tight radius 90* bend towards the inner fender well, that you had to cut on the electric fan for clerance. Then It was either a 4'' or 3.5'' pipe going to the filter.
Old 12-12-2007, 03:14 AM
TT-TECH Veteran
Inspector12's Avatar
I know you guys are going to laugh, but PEP BOYS has a section of intake piping they sell with aluminum pipe at different angles. The name brand was Spectre. Here ia a link to a picture I found of what it looks like they sell them in 2,3,&4" sizes and variable angles.
nonsponser link
Last edited by smokinHawk; 12-12-2007 at 07:25 AM. Reason: nonsponser link removed
Old 12-12-2007, 03:16 AM
You are right, that made me laugh.
Old 12-12-2007, 03:22 AM
TT-TECH Veteran
Me too, but I was able to fab up a nice intake for my F1 without any special tools or welding etc... LOL!
Old 12-12-2007, 03:23 AM
BUT..its still from the ricer section, lol.
Old 12-12-2007, 04:06 AM
TT-TECH Veteran
Yeah but not for a ricer car LOL!
Old 12-12-2007, 07:28 AM
MIGHTYMOUSE's Avatar
are you serious!! like pep boys is a rival to our sponors... geeeeezz guys.
i imagine the tti street kit (76mm version) elbow would work for you.
Old 12-21-2007, 11:34 AM
SPRAYED 01's Avatar
I call stainless works and they dont have any info on the kit anymore. I cant find any pics on here either. Any more help would be great. I actually used the pep boys stuff and went from 4to 3inch. I just think that might be to restrictive. How many guys have a reduction on the inlet?
Old 12-21-2007, 12:07 PM
did you call turbotechnology?
Old 12-21-2007, 01:59 PM
SSilverSSurfer's Avatar
thats what i was thinking
Old 12-22-2007, 11:15 AM
deadmanTA's Avatar
Isn't the pep boys stuff plastic!
SPRAYED 01---Go to the parts department at a dealership for kenworth, freighliner, Mac, ect. I just got 4" elbow $21 and a 4" to 3" reducer $16.
Old 12-26-2007, 08:58 AM
SPRAYED 01's Avatar
deadman TA, do you think the 4to 3inch in going to restrict any power? I have that setup right now but i would imagine it would hold back the turbo since it was designed to be a 4inch opening.
Old 12-26-2007, 02:52 PM
TT-TECH Veteran
Any restriction will cause a loss of boost or air moving etc... If you are not pushing the turbo etc..then a boost controller will fix that to a point. The TTI kit SSilverssurfer and MM are talking about is almost an identical set up so I would think the intake pipe would work without an issure. Good luck.
Old 12-26-2007, 05:08 PM
deadmanTA's Avatar
Since it's on the inlet I don't think it'll be that bad unless you're going for all out power. Like Inspector12 said you can always crank the boost up another psi.
I got mine to build a 4" DP off the turbo and connect to the 3" catback.
