Who's running a Ford style TB?
Im running a Ford style Affufab TB (see sig). I was wondering what people are doing for a throttle cable? Any pics would be apprecited!
Thanks - Ron
Thanks - Ron
Did you weld someting on the Ford TB so you could use a LS throttle cable? I know the Ford TB opens the oposit way a LS one does, (tipical Ford) so the cable will have to come from the bottom instead of from the top.
BTW What your intake tube made of? Looks ceramic coated! Looks very nice and matches your hot side.
Thanks - Ron
Thanks - Ron
Accufab sells a spacer plate with two ears for bolting a ford style cable bracket. Buy a lokar 1000u36 cable, but use the factory GM cable inside the lokars housing so that the ball doesnt slide through the plastic clip at the pedal.
click on my sig to see how to set it up
OWN3D BY MY PROF!
