need of procharger info
Old 12-23-2007, 02:37 PM
dragracer44life's Avatar
Default need of procharger info
i have a 2002 z28. it runs 12.4 @ 110.mph with k&n filter, mac mid headers, 3.73's, 3800 stall, truel duals w/ no cats dumped. i just added a TR cam 231/237-592"/602"-112. and obv the whole kit with it. i never ran it yet to see wat it runs but i want to put a turbo but i dont want to change my exhaust, so i was thinking of a procharger. anything u can give me for info, or where to look? thankss
Old 12-23-2007, 05:56 PM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=798
Check this complete kit out that we put together. Bob
Old 12-24-2007, 02:51 PM
how much boost should i run with stock bottem end?
Old 12-25-2007, 08:03 AM
EPP
EPP's Avatar
Thumbs up
8 psi is what we run on the LS1/LS6 and 7 psi for the LS2 engine. Bob
Old 12-25-2007, 06:56 PM
is it ok to run a procharger with a cam this big? and is 10 psi too much to run?
Old 12-25-2007, 08:35 PM
WAHUSKER's Avatar
Probably not the cam most people would choose for boost with a stock motor, but an ATI at 7 psi should drop a second or so off your times. IF you can get it to hook up. I'd buy a D now (trust me, you'll upgrade it later anyway if you get a P) & pulley it down. Then when you blow this motor up, the D will be enough for the stroker mtor you're going to buy.
Just trying to show you the path you've started down.....we all run meth to prove we're addicts.
Old 12-26-2007, 04:48 AM
EPP
EPP's Avatar
Smile
lol, so true.
I wouldn't run 10 psi on a stock bottom end unless you are prepared for rebuilding the engine. It may last and it may not, but if you can't afford an engine build, then don't run 10 psi. Methanol will certainly help to keep it together though. Bob
Old 12-28-2007, 04:07 PM
well is 8 pounds of boost gonna blow my motor up or what? u just agreed that it was. and if it is should i go with the 5-7 psi with the 38 pound injectors?
Old 12-28-2007, 06:15 PM
EPP
EPP's Avatar
Thumbs up
No I didn't, I said I wouldn't run 10 psi. We set our systems up with 8 psi all the time without any problems, but there is a big difference between 8 psi and 10 psi. I wouldn't mess around with 38 pound injectors, I'd go with 60 pound injectors.
Check out this kit. http://www.exoticperformanceplus.com....html?item=798
Bob
Old 12-28-2007, 06:35 PM
WAHUSKER's Avatar
That kit will do the trick alright.....call Bob yet? You will eventually, might just as well start off with the right kit!
