Current Rear-Mount Records...
Ok gents.. I need your help. Sense I am making a run at a couple of the records out there... I want to make sure I know what the goal's are. Please provide any input... (Verified info only, not **** house lawyer)
Fastest Rear-mount in the Nation: Majorspray.....7.54 @ 187...106mm Turbo
Fastest A2A Rear-mount (not A2W): Stealth TurboC5...9.33 @149....t76 turbo (CAN anyone verify he is A2A?)
Fastest Non-Vette Rear-mount: Blewbyu GTO... 9.703 @143.23..... 88mm Turbo
Fastest Rear-Mount F-Body: ZOMBIE...10.13 @ 132.72... 76GTS Turbo
Fastest Rear-Mount (Stock Bottom end): 1320...10.20 @ 133... ??? Turbo
Ok.... that is what I know of... anyone else chime in?
Yea, I had the f body record for about a year till zombie went the 10.13. On the upside, I built BOTH cars so it doesnt really matter to me. The 10.20 car, is a 99 camaro, stock bottom end, zo6 cam, west coast cylinder heads (317's), 9 inch with 3.00 gears and it was on a 26/11.5 et street tire on stock wheels. th400.
10.20 @ 133 1.506 60
FYI, by the end of 08 look for f body times in the sub 9.40 area.
i wasnt running to make a record and i didnt floor it the whole way but i managed a
12.3 @ 122
i know if i had suspension and a nice sticky tire i could do a high 10 and add more mph.
this was at 8 lbs.
12.3 @ 122
this was at 8 lbs.
.81 p trim 76. Coated jet hots, to my y pipe to turbo. Despite the time I was told it had about 2 ft of air under the front tires. On earlier 10.5 passes it was up about 12-18 inches , that was the fun part.
