rear mount
Old 01-06-2008, 01:55 AM
93blacktransam's Avatar
Default rear mount
What is the cheapest way to do my oil system on my remote mount turbo????... and what all do i need like lines and fitting wise and where to i put the line for the oil i know somewhere around the oil filter can someon explain this..... this it the turbo I
NLET 3"
OUTLET 2"
BEARING TYPE WET FLOAT BEARINGS
OIL INLET 1/8 NPT
MAX PSI CAPACITY 35PSI
COMPRESSOR 60 AR
61.7 TRIM
EXDUCER: 2.72" . INDUCER: 2.13"
TURBINE 1.15 AR TURBINE
133 WHEEL TRIM
EXDUCER: 2.32" . INDUCER: 2.92
Old 01-06-2008, 02:25 PM
anybody help me
Old 01-07-2008, 01:19 AM
nz12's's Avatar
well the cheapest way may not be the best for the turbo. you need a good return pump and proper feed and return lines.
http://www.rbracing-rsr.com/oilsystems.htm
Old 01-07-2008, 10:14 AM
BFEGTO's Avatar
dont go cheap. if your pump fails, that could lead to engine and turbo failure. this is the pump i used, they have great customer service and a very nice pump.
http://www.turbowerx.com/Scavenge_Pu.../Exa-Pump.html
Old 01-07-2008, 11:41 PM
I need more help i posted more ?
Old 01-08-2008, 10:50 PM
2002ws-6's Avatar
Cheap Is not the way to go, I spent over $1000 making a working self contained oiling system. Now that I've done it, I could probably do it again for a few hundred less. Brass gear good oil pump=$200.00 Hell I spent over $200.00 on -6an lines and fitings.
