Going APS TT---Have Some Questions
This will be my first turbo setup. For those that have installed this system, what would you suggest to "Upgrade"? Or what would you have done different in hindsight? My engine internals are stock for now.
How well do the following items affect performance?
90/90
cam....( not sure but like the ms4)
UD pulley
42lb SVT inj
electric cutouts
90/90
UD pulley
42lb SVT inj
electric cutouts
The 90/90 won't be worth the expense on a turbo engine as air is already being forced through the TB and intake. Not that they wouldn't help some but not as much as a all motor engine and they cost so much.
Turbo engines need different cams than other types. If that's your Z06 in the sig pic then your factory cam is already pretty good for a turbo, in fact I would leave it in unless you have a well established turbo engine builder or knowledgeable cam grinder spec you a replacement. Turbos build higher exhaust backpressure than boost so a cam with little over lap (wide lobe separation like the z06 at 117* and a smaller exhaust duration than intake like your cam are usually the turbo specs. Leave it in, it's actually a turbo cam.
UD will increase accelleration mainly from reducing crankshaft wieght and slightly by reducing accessory drive speeds. I would use a lighter wieght aluminum pulley in the stock size to achieve 80% of the gain but still have adequate alternator output at idle. Been there done that, low voltages at idle cause all kinds of weird stuff that is best to avoid.
Injectors are good idea, ask the turbo kit maker what size they recomend for your intended boost and mods. Upgrade the fuel supply system also with things like larger pump kits and or a voltage booster that is turbo boost referenced.
Exhaust cutouts? LOL This won't work with a turbo. They elimate back pressure in the exhaust by venting into open air. The exhaust has to go through the turbos to build boost, if you by-pass them they will do nothing. And if you were thinking putting them in after the turbos then once again it's a no go. Here's that deal, the turbos reduce exhaust noise so much that most people run strait pipe off of them anyways, no mufflers to by-pass with cut-outs. So save that money and run without mufflers, if you think cut-outs sound good you'll miss some of the noise with open turbos.
I recommend your order and read the book Maximum Boost by Corkey Bell. It's easy to follow and is full of invaluable information on turbo charging.
Vernon
Vernon
Yes, I agree. That is if you're running mufflers or catalatic convertors and you install the cut-outs directly behind the turbos. But if your running off road open pipe from the turbos back then I doubt it's worth the trouble and expense.
Vernon
Vernon
Thanks for the info. I was thinking about the cutouts since I will be loosing my headers. Currently I am running Kooks 3in into corsa pace cars. I love the sound. Part of what has stopped me from doing the turbo, is loosing the sound. As I said, this is my first turbo appplication. I have allways ran N20, and currently do, however I am getting a smoking deal on this system.
Im sure I will have more questions as the install time gets closer.
I'm not an idiot, far from it so FO. How many turbo or supercharged cars have you owned? The turbos will spool even faster than open down pipes if he takes that money and applies it to an electronic boost controller. Besides some people drive their cars on the street and don't spend all day at the track. I wan't my stuff to work all the time. Besides that if he runs cut-outs before any emmissions he's risking big fines and not being able to drive if if he finds the right cop. So if your going to go cut-outs and be illegal you might as well run a big down pipe to open pipe in the first place, again bringing the benefit down to nill.
Vernon
Vernon
Vernon
Vernon
Vernon
Damn, LOL, I am an idiot! You win smart guy. I'm not into internet pissing contests. To try to pin down exactly what I meant when I say "open pipe vs. mufflers" on this car with a guy who doesn't know me at all and right off the bat calls me an idiot then drags in every friends car or dyno pull he's ever witnessed isn't anything I care to do. I'm not like you at all. In example, why not answer questions with your great knowledge instead of looking for percieved mistakes to jump on and brow beat other members trying to help another? I never said TXZo603 was stupid, but it does show how you assume things about people so you can talk **** to them. Later alligator.
I'm checking out of this thread, TXZ0603 I'm local to you so PM me if you want any more of my opinions, I'd be glad to tell you mine and let you make up your own mind on what you want to do with your car. Get that book, it will allow you to make good decisions and protect yourself from getting screwed over spending good money for bad results. And if you ever go out towards Marble Falls stop by Corky Bell's shop and talk with him, he's a great guy and has more knowlegde about turbos than 99% of us here.
Vernon
Vernon
Vernon
Vernon
