2 step ?'s for a m6 car
what are the big differences between the synergy and the lingenfelter? also when you launch off of a 2 step and bog a little will the system go into vacuum or will it stay in boost? i have seen some threads where it looks like you have to switch off the lingenfelter 2 step while your launching, is this true? do you have to do this with all 2 steps?
Restricted User
When I intall my launch control, I will be using the factory preset button on my Trans Am's steering wheel, thus to make easy to hold it on and be able to realse it. The only reason I wouldn't say run it to the clutch switch is it could activate in between shifts....
Sean
no reason it would do any harm between shifts.
If your foot is on the clutch, it hardly matters if it cuts ign, and as above, can be used to flat shift.
Although with a high likelyhood of breaking traction flatshifting...I wouldnt try it !
Restricted User
I already thought about that....but if I wanted to run a 3 step I would, and plus my launch RPM is going to be lower than my WOT shift. Plus, if that lingenfelter is anything like the MSD two step, once you are above the specified RPM it wont cut, you'd have to drop RPM's and try to tach it back up to activate the two step.....
