how far can I push my 60lbs injectors with FI
I maxed out 75lbs injectors at 800 rwhp which I was told was impossible but I was at 110% duty cycle then, so I went with 96lbs now......good luck with the build.....
LS1TECH Sponsor
Depends on the fuel pressure, but if you hold 58# with the additional boost reference pressure 900rwhp will not be a problem with a supercharged application. Adding meth will even push this higher.
If you do not boost reference, the output will be inveresly proportional to the amount of boost you run as the injectors will flow less with every # of boost you add due to the fuel pressure offest.
It is all about the fuel system. You are going to need a fuel system something like what we put together on my Camaro, shown here. http://www.exoticperformanceplus.com...Car.php?car=12 Bob
I'll be testing a TTix system soon with the 60's to see how far we can push it.
Depending on the build from what Ive seen is 6-900hp......alot of other factors like fuel pump or pumps...fuel pressure etc...you catch my drift......>Actually the apexi safc is great for a piggy back style....And the greddy emanage...IS well sick....Had 4 so far!!!!
Those will maximize a/f efficiency.....Well unless you run a stand alone.....
Water meth is insane.......I run it on everything I had just about....
