Billet High Fow Fuel Rails!!
Not extruded aluminum but carved out of solid billet. Super large inside diameter & custom made AN style fittings with larger OD for maximum fuel delivery. $239 a set complete w/mounting hardware & fittings. Anodized black w/finished top. Specify if for FAST application or LS6.:thumbs: 813-628-0080
How do these compare to the others like Nasty Performance etc. and what kind of horsepower do they support and is available with all the hardware for installation like Nasty Performance kits.And are the billet aluminum that mostly everyone sells better material If not why what are the differences.
Ours do come with all the hardware & fittings needed, and we will offer 2 different fuel line options...1 with steel AN swivel fittings at $119, & 1 with Alum AN fittings in red or blue for $139. They will plug into the stock fuel line. On big HP applications you will need an entire fuel system for it.
They support over 1,000 RWHP.
We are also going to offer it w/a ligued filled fuel pressure gauge as well.
