Almost 700 rwhp with 10.5 psi APS TT kit
Old 02-09-2008, 03:36 AM
JMBLOWNWS6's Avatar
Default Almost 700 rwhp with 10.5 psi APS TT kit
Well today we got a late start on my car. Had a mustang on the dyno most of the day and we finally got a chance to put my car on there. I didnt have time to mess with the e boost so we decided to do some pull's as is. The car has been seeing 10 to 12 psi on the road (As much as you can watch a boost gauge and drive). But today on the dyno the intial spike was 12 psi then sayed right at 10 psi all the way up. I am impressed so far since I planed on running 18 psi when the new high boost duct's are done. This is thru a 4L80,stall,nine inch and a 28 X 12.50 tire. So there is alot more left in it. I just need to correct some minor vac routing and put the meth on it. Then we can lockup the converter and run a higher boost setting. I am happy and hopefully it has enuff to run a single digit in about 18 hrs from now Here's a video I threw together and the dyno graph. Nevermind the squeal its my belt I can say one thing. I didnt gain that much power with the cutout's open vs them closed. It was only good for like 3 hp and 12 tq. OK I need some sleep!
Old 02-09-2008, 03:46 AM
lethal zo6's Avatar
looks good cupcake. crank up the boost and get rid of the music
Old 02-09-2008, 03:57 AM
JMBLOWNWS6's Avatar
I cant got to sleep. I like the music. The OG video has the dam belt squeal thru the run.. I must fix it later today!
Old 02-09-2008, 05:51 AM
Websy21's Avatar
Damn nice power on low boost, I want to see it now with some higher boost
Old 02-09-2008, 06:29 AM
LS1Tech Sponsor
Slowhawk's Avatar
Nice power through the 4L80.
EPP
EPP's Avatar
Looking good, you're going to have a lot of fun with it! Bob
Old 02-09-2008, 08:41 AM
Restricted User
Zero4488's Avatar
Awesome numbers....what size motor and what compression? I'm trying to do a similar setup.....
Old 02-09-2008, 09:55 AM
MY99TAWS6's Avatar
That looks excellent for a 480le. So you have a 402.Now what do you have for heads, exact cam specs ,intake manifold and tb,compression ratio. What was your afr and timing?
Where is the torque lines? Why did the one run end at 6200 and the other one at 6500?
Did you notice any sucking closed yet of the rubber intake pipes?
Sorry for all the questions but inquiring minds want to know. Oh and was this on just pump 92 or what octane?
If you were just on pump then with your alc hooked up would expect to see quite a bit of improvement as you can crank in more timing,lean it out possibly some more and of course dial up the boost. I really want to see those torque lines. I find torque really comes up with additional timing.
But don't get me wrong your numbers are already impressing me. Will of course be anxiously waiting for some driving impressions especially how the turbos pull as you go from about 6000 to 6500. The one line looks real good though not much drop off up there at all .After all we have a lot of naysayers on this forum about how the aps turbos are way too small for your 402 or my planned 408.But on the street a bit small is better than a bit big. And if you can hit 10s with "too small" turbos or a 9 then really what does it matter. Most factory cars have smaller turbos than optimal since smaller turbos spool up quicker and widen the powerband where its most useful on the street.
So assume you have some driving impressions or did you trailer it to the shop or thats where its been sitting while you worked on it?
Old 02-09-2008, 10:44 AM
Murdock's Avatar
Post #56 in this thread:
https://ls1tech.com/forums/showthrea...ght=aps&page=2
Old 02-09-2008, 11:51 AM
MY99TAWS6's Avatar
Might as well copy it as long as nothing has changed..would still like to know exact cam specs or even just pm me with them if you want to keep the under the radar.Scouts honor won't tell! Just want to see how much cam is needed to get those kind of numbers
Engine- LS2
Block(CI): 402
Compression: 9:0:1
Oiling:Meling,moroso oil pan
Crankshaft:Callies
Connecting Rods:Callies
Pistons:Wiesco
Cylinder Heads:Trick flow 235's, L19 head studs, Fel pro gaskets
Camshaft: Custom (Cam motion)
Rocker Arms: Yella Terra
Intake Manifold: Vic JR ported and matched by LME
Ignition/Computer:Stock
Exhaust: Lethal performance true duals out the back with borla XR1's and DMH cutouts
Cooling System: Stock
Fuel- Nasty Performance Fuel system
Pump: Magnafuel 4303
Injectors:Mototron 60# / 96# versafueler
Rails: Edelbrock
Drive train/Transmission-
Transmission:4L80 MVB with lock up
Clutch/Converter: Pro Yank 3400 extreme
Driveshaft:ACPT carbon
Rear Axle:moser 9"
Old 02-09-2008, 11:52 AM
MY99TAWS6's Avatar
Oh also fighting to decide between nasty fuel system and aps fuel system. How loud is that 4303 really ? My car is pretty much pure street so trying to keep things as stock sounding as possible,within reason.
Old 02-09-2008, 12:03 PM
xLBx's Avatar
Very nice !
Old 02-09-2008, 12:04 PM
NA$TY-TA's Avatar
Bad *** man.... shes going to be a beast
Old 02-09-2008, 12:07 PM
bad95killer's Avatar
Very impressive man & get to the track ASAP
peace
Old 02-09-2008, 01:19 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Congrats, sounds like the combo is right where it should be at that boost level. Is your 4L80E an automatic valve body setup?
Old 02-09-2008, 02:49 PM
fenix999's Avatar
cant wait to see what 18psi looks like good stuff, congrats man
fenix999's Avatar
you mean manual valve body right ?? lol
Old 02-09-2008, 02:55 PM
TT-TECH Veteran
Inspector12's Avatar
Congrats JM can't wait to hear times.
Old 02-09-2008, 04:04 PM
JMBLOWNWS6's Avatar
LOL I think it would be less at 10 psi. Yup Manual valve body Im running it tonight.
Old 02-09-2008, 04:19 PM
barnat's Avatar
Default LS2 carbed aluminum intake verses LS for FI?
Hey guy,I see your useing a Vic jr intake!My tuner told me I'de be better off tuning wise to use a Gm aluminum carb intakePart#88958675 which list for$514 my cost $435 and use one of those adapter plates with a 90deg elbow and TB. I just dont know if this would clear my stock SS hood?I also noticed with the vic jr,It looks like you had to trim the cowl a bit?Just wondering what your thoughts were on this conversion for my APS 6.0 build guy The reason I was thinking of doing this is because Im selling my complete LS1 long block and verses rebuying an LS6 intake which only has a 78mm opening .Ide be about the same, cash wise going with this carbed intake! which I would have ceramic coated for looks plus have that nice straight piece of pipe from intercooler to the TB for meth or AIT sensors or what have you!Anybody done this yet with this intake?Its theLS2 4 barrelintake manifold Part,88958675!
Quick Reply: Almost 700 rwhp with 10.5 psi APS TT kit
