twin t76 spool time
Old 02-16-2008, 10:27 AM
crashly's Avatar
Default twin t76 spool time
hey guys,
can you give me your opinion on this set up.
358 cubes,sbc , twin turbonetics 76mm turbo's, S trim turbine wheel
roller cam , dart pro 1 heads, power glide, methanol fuel, drag race only,
NO NITROUS OXIDE ALLOWED, 2 38mm w/g's per bank....
what turbine a/r should i get....????
rpm from 5500 to 8000-8500 ish
thanks
ash
Old 02-16-2008, 11:30 AM
LS1Tech Sponsor
hellbents10's Avatar
.81 a/r and f1 turbine wheels I would imagine you will be building by 4k and making full by 5500.
Old 02-16-2008, 06:38 PM
crashly's Avatar
hellbents,
thanks for reply.
already have the .81 's , they sppol to 4000rpm on flat stall, but engine will not pull up any higher, even if i wind up manual bosst valve. If i put the twin 61mm back on, it goes to 5700 rpm...
i think the 76mm turbo's arenot in there sweet spot...
just trying to gte ideas what exhaust a/r's tp put on..
how do you think .68 a/rs would go?
thanks
Old 02-17-2008, 04:23 AM
crashly's Avatar
what size exhaust a/r are you guys running with 350 ish cubes ?
thanks
Old 02-17-2008, 05:45 AM
ChrisUlrich's Avatar
Originally Posted by crashly
hey guys,
NO NOS ALLOWED, 2 38mm w/g's per bank....
thanks
ash
Why not go with twin 70mm turbos from Forced Inductions? Similar power but waaaaaaaaaaaaaaaaaay better spool time. Or even their 76mm turbos.
Old 02-17-2008, 06:18 AM
crashly's Avatar
gtk 1000's / 850 in the workshop now...
no use buying new ones
actually got them before i knew about fored inductions sales.
\thanks
Old 02-17-2008, 08:06 PM
ninetres's Avatar
thanks
Thats a lot of turbo for 350 cubes. I'd go with some ST70s if you insist on twins
Old 02-17-2008, 09:28 PM
crashly's Avatar
yeep i know...
need those turbo's to run the class...
up against roots and screw blowers
have to run minuim 6.5 @ 210 mph ......
last pass was 7.2 @ 191 mph with twin gtk m550's
on 355 cube engine
thanks
ash
Old 02-17-2008, 10:46 PM
6 Second Club Moderator
LASTLS1's Avatar
I run a .81 ar and it spools like a dream! 408ci.
Old 02-17-2008, 11:14 PM
crashly's Avatar
cool, starting to get some answers...
what stall converter you got?
even tho you have 50 more cubes....
i suppose the .68 a/r on 358 cubes would be comparable to your.81 a/r on 408 cubes???
pictures of the drag car this engine is in.
thanks
Attached Thumbnails twin t76  spool time-turbo-engine-034.jpg   twin t76  spool time-turbo-engine-037.jpg   twin t76  spool time-surecam-002.jpg
Old 02-18-2008, 12:16 AM
Websy21's Avatar
Old 02-18-2008, 01:42 AM
chuntington101's Avatar
thats nuts! what power are you currently putting down??
Chris.
Old 02-18-2008, 02:22 AM
crashly's Avatar
Chris.
engine on stand not run( raced..)....( twin gtk 1000's)
little spool up troubles..
gtk 1000/850 come with .81 a/r's hotside.... only gets to 4000 rpm ..
thinking i need a smaller a/r OR looser converter. ???
engine in drag car , twin gtk 550's
355 cubes..
magic spool, can do pro tree start.
maxed out turbos @ 33 psi
run 7.2 @ 191 with 10.2 : 1 a/f ratio ( lazy)
thanks
ash
Old 02-18-2008, 08:58 AM
Coal Mining Director
onfire's Avatar
I'd go with the 0.81 and build a converter to spool it for max power.
Old 02-18-2008, 04:48 PM
crashly's Avatar
you may be right...
ordered both...
ordered .68 a/r housings ( 2)
and new torque converter
old one is 10 inch
new one will be 9 inch
thanks to all, great input
ta
ash
Old 02-19-2008, 05:08 AM
crashly's Avatar
couple of turboed chevy altereds in australia....
white altered:
355 cubes sbc twin 61mm , mech fuel injection
runs 7.2 @ 191
black twin turboed sbc alterd:
355 cubes , twin 66 mm , mech fuel injection
runs 4.7 @ 131 ( went 1.02 60' , and backoff to not break out...lol)
and
8.0 @ 171
black single turbo altered:
498 cube ,bbc , single thumper, efi ...
runs 7.1 @ 191.5
Attached Thumbnails twin t76  spool time-altered-burnout-oct-07.jpg   twin t76  spool time-portland-launch.jpg   twin t76  spool time-altered.jpg   twin t76  spool time-markhinchelwoodaama3095040507_14.jpg   twin t76  spool time-altered-launch-oct-07.jpg
Old 02-19-2008, 10:51 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
white altered:
runs 7.2 @ 191
runs 4.7 @ 131 and
8.0 @ 171
runs 7.1 @ 191.5
Those look so amazingly bad *** and fun!
Old 02-20-2008, 02:04 AM
white altered:
runs 7.2 @ 191
runs 4.7 @ 131 and
8.0 @ 171
runs 7.1 @ 191.5
haha you guys are nuts! lol
what fuel do you have to run?? are you running chargecoolers?? how much boost do you guys normally run??
Chris.
Old 02-20-2008, 02:40 AM
crashly's Avatar
no coolers
all methanol fuel
my altered ( white one), sbc, we ran 30+ psi with twin gtk 550's (61mm) , Mech inject.
geof kelly, sbc , twin 66mm turbo's , black altered, runs 20 ish psi...mech inject
mark hinchelwood , bbc , single thumper, runs 26 ish psi..... EFI
cheers ash
p.s
twin gtk 1000's (76mm ) fitted to 358 cube sbc
will see how they go soon....
going into white altered.
same car went 6.3 @ 216 mph with all iron 366 cube sbc, with D series PSI screw charger.
hoping for same or better with twin turbo's
Old 03-24-2008, 12:51 PM
BiggO's Avatar
Default Twin T76
Im running 406 sbc,twin t76 wit .68 A.r....My boost come on hard around 3500...Planning on swappin over to .81....
http://my.att.net/p/s/community.dll?...pid=117580&ck=
Quick Reply: twin t76 spool time
