what do you think for this APS setup
hey guys what kind of power do you think my car will make with this set up
2000 z28
m6
3.73 gears
APS 8lbs
ls6 intake
42lbs injectors
twin 255
317 heads (stock)
ZO6 cam
dual springs
underdrive pulley
SLP MAF
and a good tune im thinking between 500-550rwhp i hope right hahaha
thanks guys
2000 z28
m6
3.73 gears
APS 8lbs
ls6 intake
42lbs injectors
twin 255
317 heads (stock)
ZO6 cam
dual springs
underdrive pulley
SLP MAF
thanks guys
i have the 42s already i wanted 60s but my tuner does good work and he said go with the ford 42s he likes the control he gets with them and know poeple run 60s all day but i have alot of trust in him so ill just have to wait and see how much power we can get out of them .......
I would say that you are high enough that you'll need to think about bottom end work.
Mine made 481 on a stock motor with some shitty parts and a little boost leakage........so you should be good for the 550-600 range.
i still need to get a trans built up and a 12 bolt than i want just a built 364 and hit it with all the boost i can or until the turbos are out side of there range but 630-650 is a nice number
Gotcha. Well once you are powered up, if it seems like too much gear you can drop down when you get your 12-bolt.
My APS kit is in my basement waiting for warmer weather. The car currently has 4.56 gears, which I *think* will be too much!
