turbo or f1a procharger for dd car
i have a 99ta and it has 135,000 on the ls1... am thinking of going to a forged 370 with 8.5 to 1 compression. but am not sure which will be more reliable for dd.... looking to run 12-15lbs boost on pump gas... i will put about 20,000 a year or more on it.. also will i need to pull it every year to check the bearing or should they be ok putting that many miles on it....
i would do turbo for a DD one of my friend has a f1 with a mild cam 402 and its very loud and might not be the best to drive all the time. the turbo set up can be comfortably driven and still make a lot of power.. they would both be nice set ups. search here or on the video section for blower and turbo cars
I've heard and seen a lot of ProCharger equipped engines getting in a lot of miles without any problems.
My turbo Dodge that I had years ago went 190k + miles without any problems, but oem turbo systems have millions of R&D behind them. It's going to be a tough call, and you're going to get plenty of opinions. Bob
thanks bob for responding... i have looked at a couple of the kits on your site... so 9.5 to 1 want be pushing it on pump gas even when i go to the track... though i don't plan on bumping up the boost just for the track... as far as heads go is it better to keep a smaller cc runner or does it matter that much... cause i was thinking about the trick flow 225's.... once again i appreciate the help...
Centrifical supercharger seem to run better on a little more compression than the turbos do.
As far as the heads go, I'd stay smaller with your plan of running a 370. Bob
Just a ttt for EPP
With a Procharger your main concern is belts, and with a turbo your main concern is the boost reference to the wastegate. As long as you get a well designed kit, flip a coin as to what you want your MINOR worry to be. Keep in mind that with either option, you are only stressing the motor when you WANT to. The rest of the time it really just gets normal NA stress. Also, 8.5/1 CR will leave a lot of normal DD power and throttle response on the table. I would only go that low if you really plan on cranking up the boost.
thanks guys.. i beleive i will go with a procharger when i get ready to do it.... i like the complete kit that bob sells... looks like that would cover everything i can think of that i would need
Another thing to consider is that almost all aftermarket turbo systems will eventually crack the turbo mounts. This needs to be considered for a car that is going to see 20k miles a year. This may not happen on the APS kits, with their exceptionally nice cast iron APS exhaust manifolds. Bob
