j bracket bolt help
Old 03-30-2008, 08:38 PM
Rickys S/C Z28's Avatar
Default j bracket bolt help
when i was tighting down the belt i broke off the bolt, what can i do now?? i need to take this thing and have it tuned saterday and im freaking out what can i do please help
Old 03-30-2008, 09:56 PM
any one?
Old 03-31-2008, 05:00 AM
EPP
EPP's Avatar
Are the threads still good? You should be able to just replace the bolt. Bob
Old 03-31-2008, 07:46 AM
AFASTYZFR1's Avatar
drill it out and re-tap it for a slightly larger bolt.....had the same thing happen to me
Old 03-31-2008, 07:49 AM
yes they are, so i can just pull it out and put another bolt in right?
Old 03-31-2008, 07:50 AM
cool thanks man
Old 03-31-2008, 10:15 AM
Spade's Avatar
I had mine break in the the bracket not to long ago. Just do what AFASTYZFR1 said to get it out. If you are not comfortable doing it yourself a machine shop can get it done.
Old 04-01-2008, 05:16 PM
cool im going to do see if i can get it out thanks guys!
Old 04-01-2008, 07:14 PM
Jake@EPP's Avatar
If you dont have a spare, i think i have a new tensioner setup from ATI here at the shop.
What bolt broke? The long 9/16 head that pushes the tensioner down?
Let me know asap if we need to get parts for the tune day.
Old 04-02-2008, 07:29 AM
yes thats the the one im going to pull it todayt and ill let you know, thanks man
Old 04-02-2008, 08:38 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Whoa whoa whoa! No need to drill out and retap if the threads are still good. Just replace the bolt!
Old 04-02-2008, 09:04 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Running a tap through the threads to clean them up is not a bad idea. If you do not have a tap and die set, you can rent one from your local auto parts store for a few bucks.
Keith
Old 04-02-2008, 03:07 PM
ChevyChad's Avatar
Why would you do that if all the threads are fine tho? And what AFASTYZFR1 was saying was to drill it out and re-tap it for a larger bolt. Again- not necessary unless the threads are messed up.
Old 04-02-2008, 07:21 PM
AFASTYZFR1's Avatar
Yea...only drill it out if threads are damaged....but in my case, they were damaged and sounds like we broke it the same way....
Having a larger bolt will be stronger and I powdercoated the j-bracket while I was at it
Old 04-02-2008, 09:07 PM
well i took it off to day looks like i can just run another bolt back done in it so i think thats what im going to do thanks guys for your help
