APS kit going in.......
Old 04-03-2008, 06:37 PM
Pinky93's Avatar
Default APS kit going in.......
Hey all, I know that I fairly new here, but I am really appreciative of how everyone has helped me out so far!!!!
I am working with Mike Norris and he is one hell of a top notch guy!!!!
I have the stock LS1 powered 2000 Trans Am that we are going to install the APS twin turbo kit into. I asked for advice and you all DID provide that for me!!!
I willl do what is smart on this install, I have limited funds and will do what makes sense moving forward. I look forward to everyone here telling me the truth, whether I screw up, or even make the right choice...
What I can promise you, is that I will keep you posted on how I progress and what successes and failures I have. This will help you if you go down the same road.....
More to come folks, more to come.............
Old 04-03-2008, 07:51 PM
slow's Avatar
Sounds like a good plan, we're going to have a few APS cars around here.
Ryan <-- If i ever get a chance to install mine.
Old 04-03-2008, 09:55 PM
1CAMWNDR's Avatar
Good choice and good luck!
Old 04-03-2008, 10:29 PM
Tiger2o69's Avatar
good luck.. hoping to start mine in a week or so..
Old 04-03-2008, 10:46 PM
MY99TAWS6's Avatar
Hoping to start mine in a month or so. Waiting on the 408.Nice to see some more aps cars happening.
Old 04-04-2008, 09:33 AM
deadmanTA's Avatar
They are popping up every and putting down great numbers from what I've seen so far.
What else did you deside to get with your APS kit.
Old 04-04-2008, 09:52 AM
6 Second Club Moderator
LASTLS1's Avatar
Good luck! It will be fun.
Old 04-04-2008, 01:17 PM
dman's Avatar
i helped a buddy install an APS kit on his GTO. Instructions are great and they said it would take 24 hours...... and they were right on the money. Nice kit
Old 04-04-2008, 02:27 PM
Hugger Z's Avatar
Been driving mine since September! Loving it. It is back on the road now enjoying DD duty again. So much fun!
Old 04-04-2008, 05:47 PM
Pinky93's Avatar
Here is what all I am doing now.....
APS TT kit.
BMR high clearance K-member.
MSD Boost-A-Pump.
60lb Fuel injectors.
NGK TR6 Spark Plugs.
160* thermostat.
Textralia OZ700 clutch & steel flywheel.
New GM Clutch master and actuator/slave assemblies.
GM pilot bearing.
Autometer boost, fuel pressure and wideband O2 in pillar pod.
BMR boxed lower control arms.
T/A differential cover.... maybe the stock rear will last a week or two....
I am hoping to go with either a cut-out or some cat-back exhaust, it will just depend on what other money I can steal from the kid's piggy banks! I really, really need to do Subframe connectors, I hope I can find a way to squeeze them in.
Following the financial recovery, I will work towards a Ford 9" rear, torque arm and start gathering parts for a forged short block. My thoughts right now are to go with a 6.0 block with all forged internals. I still need to study up on this though, before I make any purchases.
Old 04-04-2008, 06:21 PM
cracker's Avatar
APS TT kit.
Make sure its not the "turbo" high clearance k-member and it is the standard tubular K. Otherwise it will not fit.
-Wade
Old 04-04-2008, 09:07 PM
Pinky93's Avatar
-Wade
Wow, what's up with that? Is the turbo high clearance model K-member for another turbo setup?
Thanks for the tip.
Old 04-04-2008, 09:48 PM
MY99TAWS6's Avatar
The kit was designed around the older non turbo k member .The new turbo k member is not designed for the aps kit. So just get the right one and save some grief.
Old 04-05-2008, 07:46 AM
deadmanTA's Avatar
I'd rob my kids piggy banks, but they're just as broke as I am.
Old 04-05-2008, 07:48 AM
Pinky93's Avatar
HAHA! I feel your pain!!!
Old 04-05-2008, 07:58 AM
deadmanTA's Avatar
I'm ordering the fuelpump from Bob on Monday and I still need to pick up 1 or 2 bends to finish the DP. Just need to get some time to work on her and get a tune.
Good luck with you're build! And have fun with her.
Old 04-05-2008, 09:00 AM
Pinky93's Avatar
Good luck to you also! Shoot me some pics when you get a chance!!
Old 04-06-2008, 01:23 PM
Tiger2o69's Avatar
I hope that you dont have all the problems with the msd that I did.. Never would work right and one day it caught on fire. I will use kb from now on.
Old 04-06-2008, 01:32 PM
nvmy2000ss's Avatar
This is a great looking setup. if I was to run a turbo this would be it. Your setup looks like it will be fun.
Old 04-06-2008, 02:29 PM
transamfreak01's Avatar
set up so far doesnt look bad. one thing though. since your doing your build as you go, realize no matter how much you blueprint prices, there will always be things you will need and things you forgot. but again good lookin set up
Quick Reply: APS kit going in.......
