is 106mm turbo over kill for a 383 lt1/lt4
engine:LT1 block with splayed 4 bolt mains
Callies 4340 crank
Oliver Billet rods 5.85"
JE custom blower pistons, 9.5 to 1 with 65cc heads
Total seal rings
Federal race bearings
ARP fasteners and studs everywhere
Milodon Oil pump and kicked out oil pan with windage tray
Cloyes double roller chain
Custom ATI damper for blower, it has a BBC sized hub
AFR Competition Ported 220cc heads, exhaust bolt pattern for stock or spread port headers
T&D 1.6 Shaft rockers
Custom Competition solid roller cam, new CC solid roller lifters and pushrods
new ported LT4 intake matched to heads
1-7/8" Hedman longtube headers with 3.5 inch collectors
custom fuel rails
monoblad TB
accel 83lb injectors
brand new msd opti
new msd wires
with a built t-56 and s-60 with 4.56 gears red line at 7300rpms
Callies 4340 crank
Total seal rings
custom fuel rails
monoblad TB
brand new msd opti
new msd wires
I think it's the wrong turbo for your engine/trans/gearing setup. As a 6spd car I think you will have issues spooling it, keeping it spooled and getting it to it's effeciency range. You'll always be shifting just as it's starting to kick in. I've read that some of the
With 4.56's and a 7300 rpm redline you'll only get to 133 mph in 4th gear with a 28" tall tire. You'll need to be in 5th gear before the 1/8th mile. If you plan on trapping less than 140ish in the 1/8th the 106mm is the wrong turbo. Your injectors are also too small unless you plan on running 2 sets.
I think something with an 88mm comrpessor and a gear change to 3.5x would be a better choice.
