38 mm wastegate?
Old 04-22-2008, 06:57 PM
Dean95z28's Avatar
Default 38 mm wastegate?
Do you think it is big enough for a stock 6.0 with a TC76 setup?
Old 04-22-2008, 07:02 PM
Reject's Avatar
what boost?
Old 04-22-2008, 07:13 PM
Dean95z28's Avatar
12 - 14lbs
Old 04-22-2008, 08:09 PM
Dean95z28's Avatar
Anyone???
Old 04-22-2008, 08:20 PM
code4's Avatar
I run 38mm ultra? or super? on my 346/TC76 combo. It has not given me any probs. It held 8#'s of boost when I was tunning without any creep.
I do dump it into the atmosphere which helps. I do not believe you will have any trouble @ 14#'s
Old 04-22-2008, 08:22 PM
Dean95z28's Avatar
Thanks Code4. By the way nice ride. I have looked at alot of your Pics and I really like your setup.
Old 04-22-2008, 09:26 PM
Black X's Avatar
My 6.0L with a PT76 will be using a Tial 44mm, I chose a 44mm because I didnt think the 38mm would hold the low boost levels I am looking for.
Hope that helps a little.
Old 04-22-2008, 09:30 PM
Reject's Avatar
yeah reason i asked on boost numbers was taht the smaller the gate the bigger the boost numbers need to be to not have boost creep. when running a low boost number (like i will) you need a larger WG to flow enough in the short amount of time it has to be open. i was told that when i told them i had a 38 and was only going to be running like 6 pounds, i was told to get a 44 instead
