Help with creaking sound from rear
Ive applied Blaster Silicon Lubricant to the sway bar end links and sway bar mounts to the rear end, I’ve also applied it to the lower control arms. I tried getting to the upper spring seats but not sure how effective that was without removing the springs.
The creaking occurs when the car settles after braking or a bump.
My understanding is that shocks go bad more with usage than with time, so I don’t think it’s the shocks.
i still feel like it could be the springs. Are they known for creaking and if so is it more likely the upper/lower seats or the 22 year old springs themselves?
What else should I check?
I have a bit of similar squeaking/creaking as well (low speeds, when the rear settles) with my 19k mile '98 Z28. At first it was only in cold weather (like ~40-50°), but now it's starting to do it a bit in just "cool" temps (~50-60°). It's usually the sway bar bushings that cause this, at least that's what several other folks with low mileage original cars have reported finding. Could be the control arm bushings as well. The lubricant alone might not be enough, replacement is likely going to be necessary. I haven't bothered to replace/address mine yet because the noise is still very minor in my case. But if yours is pretty constant then I could see wanting to do something about it.
I'll probably go ahead and replace the bushings.
I came across some interesting reading regarding AT-205 Reseal and claims that it restores plasticizers and resolves this type of problem. (I said it was interesting - I have not found any proper scientific information regarding these claims and am not bought in.) There are YouTube videos of people using the product to restore car bushings.
I need to replace bushings on my truck and will be doing it the old fashioned way. Even if there was a magic product like this, I expect that it doesn't penetrate all the way into the bushing and the result is a band-aid, at best. However, using something like this might be a good way to fully diagnose that bushings are the source of a creak.
I have not heard of the product, but I'm "interested" now too. It might work better in an application where the busing is just starting to deteriorate - might get quite a few more years out of it if the product actually works. I'll have to read a bit more into it...
rubber isolators on top of springs
rubber bushings top and bottom of shocks
rubber in panhard bar
rubber sway bushes
rubber bushes LCA
pick one start from there
Me 10 years ago
Maybe these old rear bushings, (if loud enough) set off by back seat movements, could be marketed as birth control devices?
https://mgchemicals.com/products/ele.../rubber-renue/
maybe these old rear bushings, (if loud enough) set off by back seat movements, could be marketed as birth control devices?
BTW, I drove my WS6 yesterday and noticed the creaking sound coming from the rear even though the weather here is warm. In other words, my car's creaking is getting worse. Hopefully the AT-205 works out for General Jack!
Looks like I'm going to just replace the bushings at this point.
Since using AT-205 reseal last week the only additional thing I did was remove the rear springs and apply Blaster Silicon Lubricant to the tops of the rubber spring seats and the bottom spring seat. I did that yesterday.
So what made the change? Could either be the 1) lubricant on the spring seats, 2) the AT 205 reseal having a week to really seep in and soften the bushings up, or 3) driving the car to let all of the lubricants work there way through the movements.
I actually didn't drive the car last weekend when I reported in, I was just pushing down on the car while sitting still. There is still a little bit of that noise (body motion while car is still) but the noises while driving have been eliminated. So I'd definitely recommend Blaster Silicon Lubricant, AT205 reseal and driving the car a little to help solve squeaking/creaking noises from the rear.
My Formula now drives almost identical to how my old z28s did when I bought them brand new. Smooth and quiet.
