99WS6.....boost?
Old 04-30-2008, 06:32 PM
witry's Avatar
Default 99WS6.....boost?
ok well i just purchased a STS kit for my 99 WS6 it was 90k on it that car was owned by an older lady before me she had it since it was new always kept up and looked at by pontiac all oil changes and repairs by GM and all the miles are highway miles that she traveled on i got the car with 80k on it and i never abused it well here and there some but i did a cylinder compression test and it varied like 7 psi from each other and when i poped the valve cover off it looks brand new so me running 5 psi in it and occasionaly 8 with a front mount should be ok right? i dont want this to happen
thanks for all the input guys
Old 04-30-2008, 06:37 PM
MY99TAWS6's Avatar
Local guy in our car club is running stock engine with 5psi for last year or two no problems. I would be a bit worried at 8psi but hey whats life without some risk. The ls1 and lt1 pistons are crap for boosted application. Ringlands are weak,weak. Have some souvenirs of buddies lt1 sts car and another buddies procharged lt1 car. But as said lt1 use same pistons as ls1.
Don't get greedy and stay 5 to 7 tops is my advice. Unless you have money for the new engine if need be.
Old 04-30-2008, 06:39 PM
nossty1's Avatar
I think you will be fine. BUT, dont go into FI thinking it will last forever! Your car will eventually fail! Dont you want to have fun untill it happens though?
Old 04-30-2008, 08:29 PM
witry's Avatar
the car is ganna stay at 5 psi about 90% of the time only if i come across some Cobras that think they are something lol but if i hit 7 psi ill be with meth n also the front mount with a possible spray bar to keep it cool and the power wont be used all the time as long as i stay out of it right
Old 05-01-2008, 08:47 AM
nossty1's Avatar
You sure are worried. I ran 10psi on my stocker with a cam, manifold and springs for almost a year and 20k miles. No problems whatsoever. If you are that worried just put in some good rods and pistons for reassurance. (That is probably not spelled right!)
Old 05-01-2008, 09:16 AM
witry's Avatar
i know i sound like a sissy sorry lol but if it blows then ill do it but like everybody is saying they are having good luck so its make me feel a little less worried as long as i dont get stupid with it...... what setup did u run with 10psi with a front mount and meth?
Old 05-01-2008, 10:33 AM
nossty1's Avatar
It was a ptk with a t70 on it. Front mount with no meth. The A4 only lasted a week!
Old 05-01-2008, 02:52 PM
witry's Avatar
i got an a4 to but it will handle 550+ so ill be ok there so i should be fine then
Old 05-01-2008, 03:34 PM
blownws6_nc's Avatar
It's all in the tuners hands, if you get a good tune, you have nothing to sweat.
Old 05-01-2008, 04:49 PM
witry's Avatar
well with that said who do you guys consider a good tuner for this setup?
Old 05-01-2008, 08:30 PM
Schantin's Avatar
Me Seriously, I tuned my own car using HP Tuners w/ a lot of help from my friend Brian at Va Speed. They are a good shop for tuning FI cars.
Had my STS installed since March 2006. 5PSI and 15K miles later it's still going well. But, I installed a FMIC and a wideband O2 to monitor the car. Both are mandatory if you want it to last a while. They are almost as important as a good tune.
Check the search on this topic. There's a lot of good info on what exactly you need (fueling, valvetrain, etc) to get it running nice....and safe
Old 05-02-2008, 01:05 AM
witry's Avatar
thanks alot really appriciate all the awesome info
Old 05-02-2008, 01:07 AM
witry's Avatar
anybody local here around the tampa fl area know any good tuners
Old 05-02-2008, 09:11 AM
smokin2001formula's Avatar
Search the name Tlewis on here. He is a sponsor and his sig says that they handle all types of FI needs for the ls1, ls2 crowd in SouthWest florida. I have no personal experience with them, but they do seem to do top notch work and are good people from what I read here on the site.
Old 05-02-2008, 02:22 PM
Found his shop. It is Rev Xtreme to the right in the sponsor's list. They are right in your area I do believe.
Old 05-02-2008, 04:40 PM
TLewis4095's Avatar
Thanks Smokin!
We are forced induction specialists & have a 1,000 RWHP car in the shop right now to look at if you'd like to stop in & see as well as just finishing a 07 C6 procharger. You will be fine on 5-7 all day long with a good tune as mentioned above and our tuner is a full time tech in our shop that knows how to make it safe. Give us a call if you want more info
Old 05-02-2008, 07:20 PM
Hugger Z's Avatar
I put my kit on at 89k and am at 96k now. 7psi, safe street tune, no issues. Just get in and drive. Stock engine, just upgraded the valvesprings, pushrods and fuel injectors/fuel pump.
Old 05-02-2008, 09:18 PM
witry's Avatar
so doing the valve spring and pushrods is a must or a necessaty... if i dont do the spring and push rods will it float the valves at 5 or 7psi
Old 05-03-2008, 07:28 PM
witry's Avatar
but if i have the front mount and meth a 7 psi will i still float the valves or that has nothing to do with it.... will it still float with the front mount and 5 psi
