LT1 Turbo Longblock is finished at last!
Old 05-03-2008, 10:58 PM
mightyquickz28's Avatar
Default LT1 Turbo Longblock is finished at last!
Well, at long last, the long block is ready. My Turbo engine builder, Mr. Jim Pitcher of Chatham, New York emailed me last night (5/2/2008) to let me know, the Beast is done! Jim is locally renowned for his engine work on shorttrack racers and came highly recommended. Jim is very meticulous and spared no effort on getting everything just right. The file-to-fit rings have the correct end gaps for this turbo application, the former two bolt main has been converted to a splayed four bolt main using ARP studs/bolts. He pressure tested the water jackets after the four bolt conversion to make sure we don't have any unexpected hydration problems after she's fired up. He balanced the entire rotating assembly. He degreed in the custom Bret Bauer Cam, got the valve springs height uniform and set to Brets specs, measured and ordered custom hardened pushrods, bead blasted the heads and intake and clear coated the intake. He also welded a -10 bulkhead fitting onto my Canton Oil Pan for my T76 Turbo's oil return line.
Specifications:
Size: 355 cubic Inch
Block: 2 bolt converted to splayed 4 bolt. ARP Main Studs/Bolts. 4.030 bore.
Crankshaft: Balanced Forged SCAT. 3.45" stroke
Rods: Forged 5.7" H-Beam, ARP rod bolts
Pistons: Custom Forged Diamond
Calculated Compression Ratio: 8.8:1
Heads: Ported Stock LT1 flowing 275/195 at .600" lift thru 2.00/1.55 Stainless valves
Cam: Hyd Roller, Custom Bret Bauer Turbo Spec
Rings: File to fit Total Seal AP series
Timing set: Comp Cams 9-3145 true roller
Fuel Injectors: 60# MotoTrons
Throttle Body: Stock 48mm
Head Gasket: Tried and true FelPro 1074
Oil Pan: Canton Road Race fitted with -10 Bulkhead for Turbo oil drain
Old 05-04-2008, 09:08 PM
4SFEDZ's Avatar
looks good cant wait to see some #, keep us updated!
Old 05-04-2008, 10:15 PM
I sure will!
On order right now...
LTCC... shipping 5/8/2008
http://www.bailey-eng.com/LTCC.html
PLX wide band, controller, gauge... shipping 5/8/2008
http://plxdevices.com/products/dm100/smafrcombo/
Quick Reply: LT1 Turbo Longblock is finished at last!
