How MUCH BOOST will the LS2 intake hold?
LS1Tech Co-Founder
I'm running a 348ci with 8:1 compression, that's why the combo is running a lot of boost. I should say once the car makes like a 900rwhp it should be 16x mph, I was kinda sandbagging there which is lame.
PSJ When you ran 9.44 how much boost were you running?? with 8:1 what is the highest boost you run with Pump gas???
Mighty Mouse ran 18-20psi with stock CI LS2 but little heads lifting but I dont know which heads is he running.
Jay Johnson this off topic but there is a very very old vid with Powter Camaro
(with Flame) at the track after 1/8 the T-top ejected is that you??
LS1Tech Co-Founder
9.44, I had 20 psi set on the controller but had some issues 2/3 track and the car nosed over.
I was screwing around with 16psi on the street this weekend it was fun. I'm guessing I can do about 15-20 on pump gas but we'll see.
