Are These Dyno Numbers What They Should Be?
Old 05-04-2008, 08:15 PM
bigdsz's Avatar
Default Are These Dyno Numbers What They Should Be?
A friend of mine has a 408 iron block, Callies 2" crank, Wiseco -24cc pistons, 228/238 .571/.581 115+4 cam, L92 heads, and a Procharger in his truck. CR is like 8.5/1.The Dyno Jet is at 580 rwhp. Was hoping for 620 to 640 rwhp, was that too much to expect? How about some comments.
Old 05-04-2008, 08:21 PM
ls1_chevelle's Avatar
what kind of psi?
Old 05-04-2008, 08:30 PM
bigdsz's Avatar
Sorry about that, I'm not a FI guy, It is 8#. I think it's the small Procharger with the smallest pulley.
Old 05-04-2008, 08:45 PM
TS6
TS6's Avatar
Not enough info really. What blower, what psi, etc.
Old 05-04-2008, 08:49 PM
bigdsz's Avatar
How about a P1SC at 8psi.
Old 05-04-2008, 09:02 PM
4SFEDZ's Avatar
what tranny? if its a th400 it wouldnt be to bad!
Old 05-04-2008, 09:03 PM
TS6
TS6's Avatar
Sounds OK to me then. Why doesn't he get a bigger blower? I don't see the point of having a built motor with a P1SC.
Old 05-04-2008, 10:14 PM
bigdsz's Avatar
4L60E tranny. A D1 is in the future, he built this motor for 15 psi. A TH400 is next on the agenda. I think he's just somewhat disappointed that it's not putting out like 50 more rwhp. If you figure NA he should be close to 500 rwhp, then I don't think with FI, looking for another 125 rwhp is unreasonable.
Old 05-04-2008, 10:46 PM
Sideways240sx's Avatar
its not, but thats a small blower for 400+ cubic inches...
Chris
Old 05-04-2008, 11:44 PM
yea, chances are he could be weeezin it out?
Old 05-05-2008, 07:32 AM
Frost's Avatar
... If you figure NA he should be close to 500 rwhp, ....
500rwhp through a N/A 8.5:1SCR L92 headed 408? There is his error right there....
Old 05-05-2008, 08:38 AM
bigdsz's Avatar
Where should it be then NA? And is 150rwhp from the small Procharger expecting too much?
Old 05-05-2008, 08:44 AM
nossty1's Avatar
I would think probably in the low 400s somewhere.
That little blower is probably pretty taxed on his motor. Time far an upgrade! F1?
Old 05-05-2008, 08:47 AM
HUNTER02SS's Avatar
Just going off of my motor, mine is a 377ci low compression and I only made 400rwhp and 450rwtq n/a. So I would guesstimate your 408 n/a would be around the 430-450-rwhp range. Also the P1 is to small for the motor. You are more than likely hurting the performance of it rather than helping it.
Old 05-05-2008, 10:08 AM
Vetal's Avatar
Hunter how do you know that (about 400whp)? what CR do you have?
Old 05-05-2008, 12:28 PM
badass99ss's Avatar
Could be the blower runing out of steam or the tune. I Just had mine tuned on the dyno and my first run showed 400rwhp/416rwtq. After an hour of my tuner working on it he pulled 165rwhp out of it. I have a P-1sc @ 8psi on a 9.5 comp 347. I could be over 600 but im runing out of fuel. Who did the tune?
Old 05-05-2008, 12:38 PM
veee8's Avatar
Maybe get a little more info on the CR. Stock L92's? Head gasket? How far the pistons are out of the hole? etc.. he might be lower on compression than you think. -26cc is a lot.
Old 05-05-2008, 12:49 PM
bigblock4-speed's Avatar
wow.. ya only 580rwhp with a 408ci?? Im running a stock bottom end with 7.9 pounds of boost with a D1SC and on a Mustang Dyno- my car pulled 543rwhp.... stock intake, basically stock heads, stock bottom end.. I would up to a D1SC and then you should see those 650-750rwhp with around 10psi...
Old 05-05-2008, 02:06 PM
HUNTER02SS's Avatar
That's what the dyno sheet said.
Old 05-05-2008, 06:38 PM
Vetal's Avatar
but when? you have TT, right, how did you get N/A numbers?
