STUPID DRAMA issue with my new 370
Old 05-09-2008, 08:56 PM
ninetres's Avatar
Default STUPID DRAMA issue with my new 370
Long story short......I have some bastard crank from the 99-00 6.0l trucks. Its is ~1/4" longer than all other LS/LQ9 cranks. Makes the flexplate stick out too far for the starter. Soooooooooooooooo
Anyone ever ran into this problem before? TCI was no help and TSP said to run a GM flexplate for these trucks which does not help my NHRA certification for 8.50.
I'm crossing my fingers a starter for this year truck would be the fix. Whatcha all think?
PS--I ran the flexplate backwards for the break-in of my motor but that isn't safe once I start leaning on this bitch.
Old 05-09-2008, 08:58 PM
ls1_chevelle's Avatar
shittty deal, no help but yea its from the iron headed 6.0l
Old 05-09-2008, 09:56 PM
trans2000am's Avatar
no problem with mine
Old 05-09-2008, 11:03 PM
ninetres's Avatar
What year is your crank?
Old 05-09-2008, 11:14 PM
Derek @ EDO's Avatar
Are you using a 99-00 80e?
If so, the starter should fix your problem.
If not, you've got another problem
Old 05-09-2008, 11:51 PM
Websy21's Avatar
Damn does that suck, another issue.................... you've had great luck with TSP thus far!
Old 05-10-2008, 12:00 AM
that i have no clue....how did you find out your year?
Old 05-10-2008, 12:05 AM
borninatransam's Avatar
you could always swap starters out.
Old 05-10-2008, 12:40 AM
sr71bbjr's Avatar
what about the converter spacing?Who built the motor? Those cranks aren't always in iron headed motors.I've picked up a few 6.0's with them and they had 317's on them(lq4's)
Old 05-10-2008, 01:03 AM
ninetres's Avatar
Converter spacing is fixable by a little machining of the bosses on the flexplate, and on the converter flange. The motor was assembled by a good friend of mine, and installed (with the trans) by my other friend Matt at Caliber Customs. I have hope for the starter. Might grab one by tomorrow! Cross your fingers boys!!!!!
Old 05-10-2008, 05:54 AM
bluecamaroz28's Avatar
Exact situation happend to a friend and he resolved it by, as told by him don't quote me on this, flipping the flywheel, it was manual trans, and fabricating a spacer.
Your best shot is to get a starter for that specific truck that the crank came in, 99-00 6.0L trucks.
Old 05-10-2008, 08:10 AM
Rickys S/C Z28's Avatar
wow man sorry to here this good luck
Old 05-10-2008, 08:31 AM
xssive's Avatar
So im guessing the coils made it to you ?
Old 05-10-2008, 12:02 PM
ninetres's Avatar
You know it! Best sale ever. Still haven't installed them yet, as I am sorting out this BS. I was running the stockers for my break in. I'll shoot ya some serious feedback when I put them on!!!!
I'll keep you guys posted on how I solve the flexplate situation.
Old 05-10-2008, 04:19 PM
ninetres's Avatar
UPDATE:
At autozone, the part numbers for the 2000 truck starters are the same as a 2001 camaro, and the 2001 truck starter has a different number. I ordered one and it will be in in a few hours. Cross your fingers the teeth are a 1/4 further out!
Old 05-10-2008, 07:57 PM
ninetres's Avatar
UPDATE: Starter is the same. Apparently the flexplate must be different. ****. Who makes an SFI flexplate for this POS 6.0 crank?
Old 05-10-2008, 10:15 PM
veee8's Avatar
Can you modify the starter, ie. reposition the mount holes to compensate? Then resleeve the holes. I don't think you are going to find an sfi flexplate for those oddball cranks. Did you try a 99 starter?
Old 05-10-2008, 10:40 PM
ninetres's Avatar
All the starters are the same.
I believe the difference is so small, that modifying the mounting holes is out the window.
Old 05-10-2008, 10:54 PM
veee8's Avatar
Maybe a shim or 2? I had to shim my starter when I used a 5.3 starter on my 6.0 with a TCI flexplate. I got a new starter for the 6.0,different part #, but have not tried it yet. The 6.0 starter was more expensive.
Old 05-11-2008, 11:40 AM
ninetres's Avatar
Pics? I don't think you get how the starter is out of position. The teeth barely touch the flexplate. It needs to extend 1/4" towards the rear of the car. I can't see how you could use a "shim" to compensate.
