Wastegate Vacuum Tubing-What are you guys using?
I'm about to plumb the lines but I got to thinking, "Doesn't this wastegate get damned hot for typical vacuum line tubing of the sort you would use up on top of the intake manifold?". Are you guys using 'normal' vaccum line that you can get at any automotive store or are you using a silicone version of some type?
I don't have any pics of the tubing. It is usually black and is flexible but stiff. It is fairly thinwall, but very tough. You can get in in several sizes. Check your local heavy truck parts store.
I use -4 line as well, the last thing you want to do is have a WG line crack.
I have seen people crack WG lines and blow their engines because the boost goes through the roof.
