Pics of Oil Feed and Oil Return
Old 06-04-2008, 12:38 PM
Monello's Avatar
Default Pics of Oil Feed and Oil Return
Any pics of peoples setups would help alot.
Any home made/home depot setups are welcome.
Old 06-04-2008, 04:20 PM
Broke EF's Avatar
Hope that helps.
Sean
Old 06-04-2008, 05:52 PM
Monello's Avatar
Thats exactly what I need. Could you take a quick shot from below looking up at the return line? =)
Also, where did you buy the hardware/hose from? If you could maybe scan your reciept or let me know exactly what fittings/hoses that would be awesome.
The return line is the only thing that scares me out of the entire turbo project.
Old 06-04-2008, 06:01 PM
Broke EF's Avatar
Actually I cant, the car isnt here....because its not mine There are pics of how we did it somewhere around here (we got the idea off LS1tech) I think it was under procharger return line. Something like that. Basicly we just drilled and tapped the front of the pan, and put a fitting in there. Im sure I can get some better pics of whatever you need this weekend as were gonna be taking it all apart. PM me if you need anything.
Sean
Old 06-04-2008, 06:09 PM
veee8's Avatar
I put my drain in the timing cover.
Old 06-04-2008, 09:59 PM
Reject's Avatar
you dont have a pic of it on the timing cover? did you use the stock crank pully?
broke is taht chris's car?
Old 06-05-2008, 12:05 AM
veee8's Avatar
I dont have any close ups, there is 1 picture in my photobucket gallery (link in sig) that almost shows it, but the DP blocks most of it. Yeah stock balancer for now. On the cover there is a few raised areas for clearance around the oil pump bolts. I used those as a reference. Plenty of room, and a nice gravity drain. My car is 1500 miles away right now, so no current pics
Old 06-05-2008, 05:02 AM
Broke EF's Avatar
Yes it is.
Sean
Old 06-05-2008, 06:32 AM
veee8's Avatar
Sean
Are you guys putting the valve springs on there, so we can see what she will do ??? I have been wondering how the project was coming.
Old 06-05-2008, 07:16 AM
Reject's Avatar
they did the springs a long while back they are taking the kit off to put a couple of vband connections for ease of service.
Old 06-05-2008, 09:42 AM
Hennytime's Avatar
id also love to see a pic or two of that setup. sounds much easier than dropping the kmember and oil pan to drill/tap for a drain
Old 06-05-2008, 12:35 PM
veee8's Avatar
It is blocked where it goes in the timing cover, but you can get the idea.
Old 06-05-2008, 03:35 PM
Hennytime's Avatar
i was looking through your pics and heres another good one...great looking build too
Old 06-06-2008, 06:38 AM
veee8's Avatar
Geez missed that one, how do you post the pictures like that?
Old 06-06-2008, 09:11 AM
Hennytime's Avatar
just put [img] *link or pic location here [/img]
there are also instant buttons in the post section but i just just the [ ]'s
