EBOOST 2 questions
+1 works great, but it takes a little time to get used to. Once you go through the set points a few times and remember what is what, its pretty easy. I can adjust driving down the road.
I really like it. The EBoost2 is pretty easy to use. It takes a little trial and error to get the setpoints dialed in. Once you get familiar with it you'll love it. I really like the ability to setup multiple boost group setpoints that can be changed on the fly at the touch of a button.
You can use this instead of a hobbs switch I was jsut wondering because I bought Nasty's stage 3 system and they told me that I had to run the hobbs switch through the brake booster line to activate the second pump and I also have this controller sorry for the
the eboost2 provides a ground for a relay which is how i turn on my 2nd pump. I have it come on at 1.5psi of boost or you could have it turn on meth injection etc. with the rpm/boost settings, you could have it arm n20 to get a car out of the hole and then turn it off at a certain boost/rpm. Its very versatile but takes some time to learn.
Thanks guys for the info and help. I really appreciate it.
Anyone have pics of where you mounted it? I wanted one for my A-pillar pod, but I guess they dont make it for a 2 1/16" pod. So I guess I will just keep my boost gauge up there and put this controller somewhere else. Maybe in the center console? Any idea's? Pics?
Thanks again.
Thanks again.
Thanks again.
Thanks again.
PN: atm-10212
damn I guess I could just find a meth kit and have it activate under WOT. Thanks for the help!
