Eboost 2 with a twin turbo application
Old 06-22-2008, 10:41 AM
50_Dave's Avatar
Default Eboost 2 with a twin turbo application
Do you have to use 2 solenoids or just use a "t" fitting to control the wastegates?
Old 06-22-2008, 03:19 PM
Coal Mining Director
onfire's Avatar
I've done it both ways....both will work...single solenoid will have a higher duty cycle vs 2 solenoids.
Old 06-22-2008, 03:30 PM
LS1Tech Sponsor
Superman09's Avatar
i run just 1 solenoid with my APS kit and it seems to be doing fine!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 06-22-2008, 07:02 PM
70Stang's Avatar
Dave - both ways work great.
Old 11-14-2008, 10:53 PM
barnat's Avatar
Default one here
I bought and use a single forge unit part #FMUNOS
Old 11-21-2008, 02:10 PM
lowbirdws6's Avatar
Turbonetics recommends using two so I went ahead and bought the second one. Can't tell you how it works though, I'm still looking for a replacement mitsubishi cartridge for my f-body passengers side APS kit. Mine went bad after only a months use, oil burnt on hot side and all over on cold side. The shaft is bent and the impellers are wasted. What a drag!!!
Old 11-21-2008, 05:00 PM
jason02Z's Avatar
i run 2 with my AMS controller one's a increase and the other is a decrease
Old 11-21-2008, 05:32 PM
MY99TAWS6's Avatar
I also caved and bought two but likely not going to be hooked up till spring.Cars is sleeping for the winter now.
Quick Reply: Eboost 2 with a twin turbo application
