which block for big turbo power.
was looking originally at the 6.0L block w/ truck heads done by WCCH.
buddy last night got me into thinking about an LS2 or LS3 setup.
cubes around 370 was going to keep the stock crank for the iron and ls2 blocks.
the LS3 however at 6.2L will it be weaker? with thinner cylinder walls from the bigger bore?
looking at making over 1,000 when set to kill...750ish on pump gas.
the iron seems hard to beat, but I want this car in the 8's....is the extra weight really that big of a problem?
Chad
Chad
LSX iron, nothing better for BIG turbo power. 6 bolt heads too.
the iron seems hard to beat, but I want this car in the 8's....is the extra weight really that big of a problem? Not when you can make the additional power needed with the iron block to go that extra .10 of a second.
short answer: don't know yet. may get a pull out motor as well.
Chad
we can set you up with a great iron 370 shortblock if you're interested.
let me know.
http://www.speedinc.com/enginepackages.cfm - good for window shopping.
let me know.
