Plenum Box Exploded! (Procharger Race Bypass info needed)
Old 07-05-2008, 09:27 PM
AFASTYZFR1's Avatar
Default Plenum Box Exploded! (Procharger Race Bypass info needed)
My metal plenum box exploded today with 14psi at around 6k.
I guess it was my own fault for trying to use plastic procharger bypass..
Going to weld up plenum box all around since welds from procharger didn't even penetrate the metal and strengthen it up some
I am going to get a procharger race bypass....also going to run twin intercoolers for now, but can I weld the race bypass flange in where the plastic bypass connects? or do I just need to mount it on the plenum
btw....I am tuned in speed density....and think I want to recirculate
Old 07-05-2008, 10:07 PM
AFASTYZFR1's Avatar
guess I answered my own question........but would the bypass be better on the plenum, or after intercooler on driver side?
Old 07-05-2008, 10:17 PM
Silver_TransAm's Avatar
Either way would wrk.
Cant belive it came apart like that, first time I've seen that!
Old 07-06-2008, 08:17 AM
99.9percenter's Avatar
[QUOTE=AFASTYZFR1;9683746]My metal plenum box exploded today with 14psi at around 6k.
http://www.procharger.com/store/imag.../3FASS_007.jpg Why do you want to recirculate?
Old 07-06-2008, 08:35 AM
Rickys S/C Z28's Avatar
man iv seen this a lot but i never had any problems with my plastic one??
Old 07-06-2008, 09:39 AM
SilverSS's Avatar
Mine plenum exploded twice on my old set-up. First time the top split wide open and had it re-welded. Second time the bottom split open where I couldn't see it. The car still managed to make 13psi at the time. I was on the stock bypass valve.
Old 07-06-2008, 09:40 AM
AFASTYZFR1's Avatar
I think I want to recirculate because car is already loud enough and don't really know if there is a big advantage to venting to atmosphere
Old 07-06-2008, 09:44 AM
AFASTYZFR1's Avatar
here is my plastic one from last year......either you arn't running alot of boost or you don't hit it hard......but either way i hope it holds up for ya
Old 07-06-2008, 10:02 AM
DanWS6's Avatar
That's how I plan to run mine. Although it's open to atmosphere.
Old 07-06-2008, 12:12 PM
helicoil's Avatar
Damn! I guess all that crap really was designed around the P1SC and 5-7lbs.
Old 07-06-2008, 02:32 PM
ZDOG's Avatar
little super glue and thats good to go!
Old 07-06-2008, 05:13 PM
EPP
EPP's Avatar
Since you cracked the plastic one and the alum one, I would take a good look at your bypass valve. I've heard of several people cracking the plastic plenum at higher boost levels, but I don't recall us ever having a problem with it. Let alone, the alum plenum!
The race valve will certainly help you out. Bob
Old 07-06-2008, 08:29 PM
Frost's Avatar
Hey Bob, it definitely happened during bypass...
We are 2/3 to 3/4 done with his 2-bar tune, and this was the first full pull to 14ish psi As soon he as he let off, *POP* and then no boost
Can't wait to put some pressure to this bottom end that you guys put together
Old 07-06-2008, 08:51 PM
Jake@EPP's Avatar
Ive seen the plastic ones swell up like a balloon at 16psi
Never seen one blow up, but those welds dont look like they even penetrated enough.
The motors built to take what you throw at it, what pulley you guys tuning with?
Old 07-06-2008, 09:12 PM
wow man and your right im not running big boost yet, but it wont matteer because i have a FMIC from EPP
Old 07-06-2008, 09:23 PM
AFASTYZFR1's Avatar
SDCE 7.25" crank/ 3.4" blower
Should I go with vent to atmosphere or recirculate (any chance of unfiltered air entering with the vent to atmosphere.....don't think so but want to make sure)
Car also might get caught in rain
I plan on welding flange above driver side intercooler.....that pipe is steel, right?
I will be giving epp a call in the morning to get one ordered
Old 07-06-2008, 09:27 PM
Frost's Avatar
I'm not sure what the size is to be honest, I'm sure David can chime in.
We saw something like 200 kPa at 6-6200RPMS (I forget) which is about 14.5 psi. Any idea where we will end up at boost wise from 67-6900?
He is running Alkycontrol meth (straight meth) and the kit is cranked up That thing moves a lot of meth!
Old 07-07-2008, 04:48 AM
EPP
EPP's Avatar
Thumbs up
You'll probably see it max out around 16 psi. If the power dramatically falls off for you at some point, try toning down the meth. Bob
Old 07-07-2008, 09:10 AM
Ponyhntr's Avatar
I would definitely go with the open (vent to atmosphere) because if you recirculate then you would be recirculating hot air. I would also put the valve between the blower and the intercoolers for basically the same reason, you don't want to heat up the intercoolers if you don't have to.
You will not get dirt in through the bypass as there will always be air blowing out, never in.
Old 07-07-2008, 09:26 AM
Frost's Avatar
Thanks Bob! I don't expect the power to fall off at all, we aren't gonna drown the car, the final AFR will be where it needs to be. At 9.5:1 SCR and 15-16psi on pump gas I think we are gonna need that methanol
Quick Reply: Plenum Box Exploded! (Procharger Race Bypass info needed)
