Procharger pinning kit with Eagle crank??
Old 07-15-2008, 05:43 PM
03 BUSA's Avatar
Default Procharger pinning kit with Eagle crank??
Can you pin the Eagle crank? I have heard that the Eagle cranks are so hard of a metal that alot of times the drill bit will not work. Just curious to how true this is. If it is true could a machine shop use something to pin the crank? Thanks for the help.
Old 07-15-2008, 05:50 PM
Shawn @ VA Speed's Avatar
I do them all the time,just got to use a drill press to get enough pressure on the bit
Old 07-16-2008, 04:49 AM
EPP
EPP's Avatar
You can do it in the car, you just have to apply a lot of pressure. Using Tapfree lubricant will help to keep the drillbit from immediately dulling on you. Bob
Old 07-16-2008, 07:12 AM
LS1Tech Sponsor
hellbents10's Avatar
I have done them in the car too, just have to use a good bit.
Old 07-16-2008, 01:36 PM
stevieturbo's Avatar
Solid cobalt drill bit, and it will drill as easy as any normal steel.
try it with a typical HSS bit, and you'll be trying forever.
Old 07-16-2008, 05:37 PM
03 BUSA's Avatar
Thanks guys. I appreciate the fast response. Bob, I will eventually be getting with you for a d1 or f1 just hanging out to see what this economy thing is doing. Had 70 guys laid off at work 3 weeks ago so I am being conservative at the moment.
Old 07-16-2008, 08:39 PM
Jake@EPP's Avatar
A good bit is they key to this, the armor is super strong and will murder cheap bits.
Old 07-17-2008, 05:28 AM
EPP
EPP's Avatar
Thanks, I appreciate it. Seeing 70 people get laid off would have me cautious as well. Bob
Quick Reply: Procharger pinning kit with Eagle crank??
