driveability w/ 96lb injectors question
Old 08-31-2008, 06:18 PM
ninetres's Avatar
Default driveability w/ 96lb injectors question
*Yes, mods I know this is the FI section.....not the fuel section. I did it on purpose*
How is your part throttle and idle with 96lb injectors/driver box and a big cam (240d/650l)? My tuner said he had trouble getting the A/F to lean out. He tried all kinds of things. I figured its just tough to get injectors that big to drive PERFECT under very light throttle. As soon as I give it 50% or more throttle its ****.
Old 08-31-2008, 06:59 PM
Frost's Avatar
what does he have the min pulse down to?
Old 08-31-2008, 07:06 PM
Tiago's Avatar
I can't get my car to idle leaner then high 10's AFR... but everything else is ok.
if I reduce the pw's any further I get alot of other drivability issues like bucking around....
Old 08-31-2008, 09:08 PM
Fryguy302's Avatar
Mine has 160's in it and idles and drives perfect. Tuner was Mike Moran though.
What kind of engine management is it?
Old 08-31-2008, 09:15 PM
Navy David SS's Avatar
Mine also has 160lb drives just fine. BUT I'm using AEM. My tuner is "turbo" whiz, I believe he can tune about anything with a turbo on it What are you using - BS3, stock?
David
Old 08-31-2008, 09:20 PM
obZidian's Avatar
I have a BS3 and gonna run a set of 160lbs. Haven't had issues with 96's, but only time will tell on the 160lbs.
Old 08-31-2008, 10:08 PM
ozws6's Avatar
I ran 96s with HP Tuners 3 bar with no driveability issues at all. Recently changed to 160s and I've had a few challenges but so far so good. It's all in the tune.
Old 08-31-2008, 11:18 PM
1320's Avatar
pm zombiess. I know you guys talk. He has 96's but runs them with a mega squirt. It has idle issues that he is still working on but a much much smaller cam. He still might have insight for ya though.
BTW, goo dto see it together, and has nice potential.
Old 09-01-2008, 12:38 AM
ninetres's Avatar
Rick at synergy is quite the turbo tuning guru too. He has tuned many of mine (and others) turbo builds to perfection.......but for some reason, my car wasn't responding very much to some changes he was trying. I run a stock PCM w/ HP tuners 3 bar.
I am a virgin when it comes to tuning terminology. But I know he mentioned something like "I tried 50-60% changes on the part throttle ve table's and saw no change". I know he tried EVERYTHING. Car idles well for the large cam thats in it, but just rich. And the part throttle is a little rich and has an interesting buck (or stumble) from a stop at VERY minimal throttle.
I just installed a new IAC valve which he said MIGHT help. I think my car needs to learn that its there a little bit.
Old 09-01-2008, 01:05 AM
Jimmy P's Avatar
My car has 160lbs in it, controlled via BS3. It idles and cruises fine, its just a little richer than I like. At idle the AFR is usualy in the 11.5-12.5 range. I am considering putting on some 83 lbs injectors in it. Whats the ideal AFR for idle and part throttle on a FI car?
Old 09-01-2008, 07:34 AM
Frost's Avatar
Originally Posted by Jimmy P
..... Whats the ideal AFR for idle and part throttle on a FI car?
stoich for gasoline is 14.6-7:1
Old 09-01-2008, 08:09 AM
NA$TY-TA's Avatar
Harlan got my 96's to 14.6-7:1 at cruise and idle with his driver box and the MAF T on my 98PCM.
Old 09-01-2008, 10:30 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I have BS3 and 96's and Intmd8 (Jim M.) tuned it, my base fuel pressure like ~40. You can't keep stock fuel pressure and run big injectors typically because most of the time you can't take away enough fuel down low.
Old 09-01-2008, 12:17 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Bingo. Give that man a prize
Old 09-01-2008, 01:40 PM
Zombie's Avatar
I'm running the 95lb/hr injectors with my MSII setup. My fuel pressure is 72psi since both pumps are on full time and i'm still running the stock returnless setup. The only idle issues I experience are in park/neutral, I get some surging. In gear it has zero issues and idles at 13.5-14.0 a/f. I'll have to do some more fine tweaking to get the neutral idle to surge less, but there is very little resolution left due to my fuel pressure being so high.
If I ever stop being lazy and wire up a hobbs switch to the 2nd pump it would probably be perfect.
Old 09-01-2008, 02:01 PM
DanZ28's Avatar
Rick has tuned 96's before with no issue so I'm guessing there is something a bit different in your setup. Like mentioned, whats you FP at idle?
Old 09-01-2008, 03:47 PM
LTLHOMER's Avatar
I had 96s in my old setup and it idled at 14.7ish perfectly. Tuned by Don Bailey.
Old 09-01-2008, 05:59 PM
Jimmy P's Avatar
What CI was the motor? Don is my tuner as well. He recommended I go with the 83's over the 96's as he likes the spray pattern better.
Old 09-01-2008, 06:13 PM
LTLHOMER's Avatar
347 cubes
Old 09-01-2008, 07:42 PM
ninetres's Avatar
Haven't checked it since he tuned it. He was fiddling with the FPR though. I THINK its in the low 40s. I'll check tonight if I go play. He said there did seem to be something fishy with my set-up.
Quick Reply: driveability w/ 96lb injectors question
