New best, got a couple questions.....
Old 09-20-2008, 01:29 PM
TS6
TS6's Avatar
Default New best, got a couple questions.....
Got 2 passes in last night (big thanks to the ******** with their POS cars oiling the track down in spectacular fashion 3 times) and went 10.14 at 139.36, 1.63 60'. Car will just not get the **** out of the hole. This convertor has to be too tight. I can't hardly foot brake it to 1500 RPM without it creeping through the beams, and no matter how I launch I'm stuck in the low 1.6's. It sucks going 139 in the 1/4 and still not going 9's. Should I try anything else before having it loosened?
Old 09-20-2008, 01:48 PM
sevanseriesta's Avatar
whats your setup? Do you have a link to it?
Old 09-20-2008, 01:54 PM
TS6
TS6's Avatar
408/D1SC at 13 psi
4L60E with 3600 PI
3550-ish raceweight
3.73 gear
740 RWHP
All the suspension goodies....
Old 09-20-2008, 02:39 PM
And you are spinning and no one else is correct. Michy Thompson Drag radials or et streets?
Old 09-20-2008, 02:44 PM
Tiago's Avatar
turn up boost till you run 9s
Old 09-20-2008, 03:00 PM
Coal Mining Director
onfire's Avatar
If it footbrakes at 1500rpm, it's killing you. I'd fix the converter.
Old 09-20-2008, 03:12 PM
Turbo Tech's Avatar
Are you using a two step? if your foot braking to stage your car the throttle blade is not open very far and will limit the air flow to the engine. If you install a two step the throttle blade will be wide open and you should build a few psi of boost too. 60' will get faster and your car should run deep into the 9's with the mph your running. LPE sells one that even has a timing retard to help build starting line boost faster. George
Old 09-20-2008, 03:49 PM
SPRAYED 01's Avatar
I have a trans brake for the 4l60e for sale. Brand new with custom trans pan.
$860 shipped
Alex
Old 09-20-2008, 04:10 PM
98Camarod's Avatar
Get that converter fixed or get a different converter. 1500rpm is not ideal to leave at.
Old 09-20-2008, 04:31 PM
TS6
TS6's Avatar
If I can't hold 1500 RPM I highly doubt a 2 step will help, that would be even more power to try and hold.
The car is not spinning, its just weak off the line.
Old 09-20-2008, 04:52 PM
98Camarod's Avatar
Shouldn't you have more converter than a 3500? I can leave at 3200 on my ss4000 and I cut 1.5's (except the last outing at the backyard track)
Old 09-21-2008, 09:28 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
A transbrake locks reverse and first gear together, it's way different from footbraking.
I ran a 10.05@137.74 @ 16 psi 1.51 6.4/111 last night on pump gas, I would say that the car was making 650-700hp on that pass and the mph might be off since I melted the vacuum line to the BOV.
I would think you need more converter, I bogged on my 1.51 since I only left on 5 psi at like 3700.
Old 09-21-2008, 09:35 AM
helicoil's Avatar
With those kind of MPH's you will be easy mid 9's if you can launch. Junk the converter, it is your problem, although it may the saving grace for your 4L60E.
Nice runs! I bet you can hook it on the street with the tight converter.
Old 09-21-2008, 11:24 AM
nuclearxp's Avatar
Either trans brake or new converter, but I'd think about the trans brake. Chances could be you're just making too much torque for the brakes to hold and if that's the case a trans brake ought to have you leaving much harder.
Old 09-21-2008, 03:07 PM
TS6
TS6's Avatar
I wish, but not even close.
Old 09-21-2008, 08:04 PM
helicoil's Avatar
With your 1.60 60's curious what you have for compression and a camshaft in that motor?
Old 09-21-2008, 08:26 PM
TS6
TS6's Avatar
Its a secret.....
j/k, but I honestly don't know. I just know that it makes killer power for 13 psi from a D1SC on pump gas.
