TC 78 Limits?
TC 78 Limits?
I have been running a turbo set up on the street for a couple of years at around 11# of boost. (no track around here) I decided this year to up the boost, I replaced the tc 76 with the new tc 78. Put some slicks on & found some secluded roads.
Well I could not get to 15#'s so I replaced the MBC with one that I know is good. I finally got to about 16 on my guage but I have yet to hit 210 KPA on HP Tuners? It hits 205 which doesn't jive with my guage right? It makes some nice power but I am wanting more. LOL
My question is can I be out of turbo? I have a 347 with afr heads, a nice free flowing kit with open down pipe. Here is another piece of the puzzle, I am at around 3500 to 4000 feet in elevation.
All my pipes are nice & tight, I don't think I have any leaks.
I just did some runs tonight & really it stayed mostly around 195 KPA no matter how much I turned the MBC up. It also ran my injectors up to 80 to 83 % DC at 11.0 to 1 afr spraying meth. So I am probably pretty close to max on my fuel.
Yes I have read everything about this turbo on this site. I'm just trying to figure my boost #'s.
Boost controllers are limited by what the wastegate can or can't do. Wanna see the real limit of the turbo? Install a block-off plate before the wastegate and be prepared to replace head gaskets at minimum. I believe that turbo can make 20+ psi on your motor.
LS1TECH Sponsor
Bingo.....wastegates are pressure regulated. Exceed the pressure and no more boost.....doesn't matter what turbo is under the hood. I don't recommend doing what Mike said....he's crazy.....turbo Jet Ski's are for the birds BTW....
I bought the WG from you guys, I think it was a 38mm Ultra? If I remember correctly. What can I get that will bolt in it's place? I don't have a lot of room for one that is physically much larger
LS1TECH Sponsor
You don't need a bigger gate...just more spring tension. Have you stacked the springs that came with the gate. The Ultra's came with extra springs to stack up the tension on the valve.
so would a tc76 be able to make more power on a 5.3 or a smaller motor because of backpressure?
relatively speaking yes those tc76's and tc78's will make more power on "smaller" motors since they will be closer to their efficiency range with smaller cubes. They are rated to 1000+hp, you just have to use them correctly to achieve that goal. Basically a bigger motor will choke the **** out of that small T4 frame turbo, thats why guys are using bigger T6 units to "start off with" since they can house more appropriate and larger turbine/compressor wheels (like the 80mm and up units somebody requested several posts above me), downside the T6 units are alittle bigger overall, which kinda sucks but who cares - who needs a radiator or fans lol/jk
