Will my combo make 700RWHP
Hi , I am building a 346 forged LS6 motor
(Diamond -8.6 blower pistons, Eagle H-beams, callies dragonslayer, DM-Girdle W/ARP main studes)
LS1 241 AS ported heads, 300CFM at .600
TR 216-231 601/580 116 Blower camshaft
FLP long tubes, no cats, SLP DD exhaust
LS6 intake/acufab 75mm ported throttle body.
D1-sc twin intercooled / alky control methanol injection
OK I need to know what you guys think, I would like to run 93 pump gas with the methanol injection (no race fuel)
I want to make around or very close to 700 RWHP.
1) Can my combo make 700RWHP?
2) How much boost will i have to make (15)?
3) with 8 rib set up and 7.65 crank pully , what size blower pully do i use,
thank you for your help
Your combination should get you similar results to this build that we did.
http://www.exoticperformanceplus.com...Car.php?car=54
You are going to need a good fuel system for 700 rwhp, and I would go with a 3.40 blower pulley. Bob
My car is a M-6 , That should help in getting the 700.
I have both 3.65 and 3.4 blower pullies, the 3.4 is the smallest you can use procharger said.
My fuel system is a Lonnies Performance/Racetronix intank double pumper, Speed inc fuel rails, and motron #60's
Alky control , LS1 methanol injection system
I was going to run the returnless stock fuel system for now, (no return) I hear i can make 700RWHP without a return.
Tunner = My friend Carmen (Vette Doctors)
O yeah, should i get a Casper LS1 Volt Booster? For a little more juice to the pumps.
I have a new KennyBell boost a pump , but the Kenny bell is for at least + 6 volts.
The casper is only a 1-2 volt booster and it boost the spark to.
let me know what you guys think.
Thanks
Thanks
