how much power
how much power
HOW MUCH POWER DO YOU THINK I'LL SEE WITH THIS COMBO ON 18-20LBS... IM HOPING TO SEE THE 1000RWHP MARK
LS2 402 aluminum block fully CNC machined
Main caps pinned to prevent walking
Lunati pro series 4.00" stroker crank
Lunati billet 6.125" connecting rods
JE custom forged pistons - coated on tops and skirts
Total seal stainless steel rings
Clevite coated bearings
AFR 225 CNC ported heads
ARP main and head studs
Custom Comp hydrollic roller cam (238-240@.050 .605-.608, 115 lsa)
Harland Sharp roller rockers
ls7 lifters
Ported ls6 oil pump
JP performance timing set
Comp Cams chrome moly pushrods
custom fuel system with Aeromotive A1400 Pump
Performa Built 4L80E Racing 4 Speed transmission with OD
Chrome Moly Drive Shaft
Y2K HP-88MM TURBO
4 CORE INTERCOOLER
All custom piping
ls7 lifters
Ported ls6 oil pump
Y2K HP-88MM TURBO
4 CORE INTERCOOLER
All custom piping
Im new to the FI seen but im starting my front mount turbo setup and im big on the whole keeping the car looking completely stock as far as AC, PS, and full weight. Then again im looking at running 6 psi lol.
I figure it's closer to 750-800 for a full weight turbo car based on the fact that a full weight car + turbo stuff + safety stuff + stronger aftermarket trans/rear is at least an addition 200lbs putting a raceweight at 3800-3850 with a 200lb driver.
My setup is 3800 race weight and trapping 135-136 mph wich puts me at the 750 rwhp AVERAGE going off the simple HP calcs. I'd guess it probably makes 780 hp at the peak.
Either way the OP should be able to go high 9's on that setup. I'm almost in the 9s with a heavy car, a rear mount 80mm turbo and 16psi of boost. Just takes time to dial a setup in and get it working consistantly.
LS1Tech Co-Founder
I'm sure Zombie, heck you'd be in the 9's now with more gear.
I went 10.05@137.8mph (1.51) at like 3400 raceweight, 16 psi, I figure that's about 680-700rwhp for me. I went 9.4@144 at 680rwhp with my old blower setup at 18 psi and 3500 raceweight, but it did 60ft a 1.35.
As for more gear in my car, i'm going the opposite direction... less gear (taller tires). Going to cross in 2nd gear instead. I spend 2 seconds in 3rd now dumping all my power into the converter at 20% slip. My slip in 2nd gear at 7000 is 4%. Going to run my TH400 like a power glide. Yes I know I'm strange, but my car is consistantly fast so it negates my wierdness. I finally got a set of skinnies to run on the car too now, no more stock SS front runners.
I doubt the OP will ever see the 1000 RWHP on the dyno, but on the track at 3800lbs it should be able to go 148-150mph, which is 1000 RWHP.
Gingervitis Addict
Thats right in the ball park according to the calcs, 690 average HP needed to go 138 mph at 3400lbs. Car probably peaked around 720 rwhp.
