Got the LSX to the track
Old 10-10-2008, 12:06 AM
6 Second Club Moderator
LASTLS1's Avatar
Default Got the LSX to the track
I had tire spin issues, not sure why. The track seemed to be hooking for other people? I had it at 13lbs doing 1/8 mile tech issues, they teched my car to 10.0's. Dew started to creep in so I turned it up to 15 lbs and gave it a shot. Breaking in the motor, that's why low boost. Anyways it when 8.9 153mph with a 1.33 60'. Not bad for low boost but I have to figure out why the car wants to go sideways on the 1-2 shift???? I ran one pass 10.1 @ 77 mph. LOL Breaking hard
Oh yea for some reason I'm letting off the gas up to 53% after letting off the trans break all the way up to the 1-2 shift where it goes back up to 97%. That's never happened before? Weird night!
Old 10-10-2008, 02:57 AM
HAMRHEAD's Avatar
What track?
Old 10-10-2008, 08:49 AM
LASTLS1's Avatar
Originally Posted by HAMRHEAD
What track?
Union Grove, WI.
Old 10-10-2008, 12:38 PM
Coal Mining Director
onfire's Avatar
Big power for low boost. Killer shakedown. Sounds like track prep/dew killed you.
Old 10-10-2008, 01:48 PM
LASTLS1's Avatar
I really can't say it was the track. Something in the chssis isn't happy. It could be the tune up? I have to recheck timing, It could be that I have more timing than big stuff is showing. I've run my car at 23 lbs and not had it do that on the 1-2 shift. It's possible when I short shifted it (6800 instead of 7500) and going back to full throttle at the same time did it.
Old 10-10-2008, 02:10 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Did you do anything with the suspension after putting the LSx block in. I know it's a decent bit heavier than an LQ block. More weight in the front might be causing it not to hit the tires as hard.
Old 10-10-2008, 02:26 PM
LS1 SPEED's Avatar
good point there
Andy have you scaled the car?
Old 10-10-2008, 02:30 PM
slomarao's Avatar
Is the motor in a F body?
Old 10-10-2008, 02:44 PM
TrakDay's Avatar
Very nice... makes me jealous!
Old 10-10-2008, 03:46 PM
onfire's Avatar
I had to raise my front springs to get my balance back after adding the LSX block.
Old 10-10-2008, 04:36 PM
LASTLS1's Avatar
No I have not. I noticed it sits a little lower in the front. It 60' 1.33, 1.33 and 1.35 I can normally run a 1.2x on a good track. It's the 1-2 shift that's a bigger problem. It could be sitting too low in the front not letting it hook up down the track?
Old 10-10-2008, 04:38 PM
LS1 SPEED's Avatar
yes..too low up front could have a good amount of weight off the rear tires.
especially on a bump or shift at a slightly rough track like GLD
Old 10-10-2008, 05:05 PM
TrakDay's Avatar
Would this also make the car feel loose on the big end!?
What kind of tire psi are you guys running!? And what tires!?
LASTLS1's Avatar
Yea Larry, between the turbos, big I/C, plumbing and the LSx that's alot of added weight up front. I'm going to weigh all four tires. I've never done that before.
Old 10-10-2008, 05:06 PM
TrakDay's Avatar
Yeah... thats our next step. My car is a pig though and needs all the help it can get.
Old 10-10-2008, 05:07 PM
LASTLS1's Avatar
28", 10.5 ,13psi The top end was fine, I was only running 15 lbs of boost.
