Position of F-body fuel tank??
Old 01-29-2009, 07:21 PM
LS1ChevyII's Avatar
Default Position of F-body fuel tank??
Hey everyone. Great site. Ive already found an *** load of inf that i couldnt find anywhere else.
But my question is where is the fuel tank positioned in relation to the fuel door? How much higher is the filler cap than the tank?
Im putting a 02 Camaro tank under the trunk of my '63 ChevyII and there is a good foot in vertical differance from where the gas door is to the top of the tank.
Will this pose an overflowing problem when i try to fill the tank?
Old 01-31-2009, 12:55 PM
slowpoke96z28's Avatar
its not a foot higher, thats for sure. are you using all the emissions stuff with the tank, or just plugging them off?
Old 02-02-2009, 06:54 PM
LS1ChevyII's Avatar
Yes im planning on using the EVAP system.
Old 02-04-2009, 09:38 AM
i think you might stand a chance of saturating the charcoal canister with fuel.
Old 02-04-2009, 01:11 PM
Soul TKR's Avatar
where is this canister located?
Old 02-04-2009, 05:44 PM
the factory spot is at an area at the top front of the tank. its a bit smaller than and old gas can. as guess, though, you could always relocate it to a higher position, so as to not cause a problem. thats the only thing i could think of that could cause a problem
Old 02-09-2009, 04:14 PM
LS1ChevyII's Avatar
Thanks slowpoke. That was really what my concern was.
Old 02-09-2009, 04:32 PM
LS1ChevyII's Avatar
Im thinking i can relocate the canister and valve up into the wheel well near the location of the filler inlet on the quarter.
What about this? Is this a vent? The tube is open ended. Should this be routed up near the charcoal canister as well?
Old 02-12-2009, 05:14 PM
i dont know what that is. my guess is that it is an overpressure blow-off valve. i would route its tube high as well, just to be safe. maybe someone else has a better knowledge of that piece.
Old 02-12-2009, 06:19 PM
davidws6's Avatar
Default Fill Tube
I think that when you fill it up, the first time the pump clicks off, STOP. Don't overfill it and you should be fine...
